Old 21-07-2006, 03:17 PM   #1
alpineau
alpineau's Avatar
Default My Car Is Grasping
Hi All
I have a quick question, My car seems to be grasping when i go to accelerate, It dosen't do it when i accelerate very lightly.
I have in the past 2 months changed or had changed under warranty the following parts
Coil Pack
Leads
Plugs
Steering Rack
A Couple Pullys and seals
I guess my question is what could cause my car to cough when i accelerate. It does not seem like a miss, i had that when the coil was failing so anyone got any ideas. The car runs fine when just idleing. I do have a humming fuel pump could that cause the problem?
OLD - 2000 AUII FUTURA 75TH ANNIVERSARY GOLD 4 SPEED AUTO
OLD - 2006 BF MK2 XR6 BIONIC 4 SPEED AUTO[
OLD - 2007 BF MK2 XR6T SILHOUETTE 6 SPEED MANUAL
CURRENT - 2009 FG G6E BLUE 6 SPEED AUTO
alpineau is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 04:03 PM   #2
Mechan1k
Mechan1k's Avatar
Heard recently the filter on the fuel pump (in tank) causing issues ... or is could be your fuel filter getting clogged.
Old 21-07-2006, 05:50 PM   #3
JC
Miami Pilot
JC's Avatar
I would say fuel pump is the issue - the only way to know for sure is get it on a dyno and have a look at the AFRs under load. Too lean (13+) would suggest fuel pump.
Ford Performance Club ACT
Old 21-07-2006, 06:06 PM   #4
alpineau
alpineau's Avatar
Hi JC
I will see if i can find a place in townsville that has a dyno, I suppose there has to be a company here that has one and it would be a good opportunity to see how much power the car is producing. I wonder then if it just better i take it in to the dealer where i brought it and see if they can fix it, they have do most of the repairs on the car under warranty
Alpineau
Old 21-07-2006, 08:18 PM   #5
XEESP_351
yeah man sounds like fuel pump does it crank for a whilke before starting? because thats a good sign fuel pump not holding pressure any1 with a fuel pressure tester or CODA should be able to find fault if exists..
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2006, 08:29 PM   #6
mik
mik's Avatar
i think the fuel filter is due for replacement at 100k service if thats any help.
Old 21-07-2006, 08:42 PM   #7
Free347
Could be buggered oxy sensor too.
Free347 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2006, 08:36 AM   #8
Tri Power 289
Back in the Game!
Tri Power 289's Avatar
Sounds like the same problem I had. I was convinced it was electrical too but turns out it was a blocked fuel strainer.
Changing the fuel filter is important but its most likely caused by the fuel strainer mounted on the bottom of the pump.
Have a read of this.
http://www.fordforums.com.au/showthr...047#post837047
Hope it helps.
2016 Focus RS MK3
XHII XR8 Falcon Ute S/C 5.0 Manual
'66 Mustang coupe 289 Auto
70 Mustang Mach1 351 4V/Shaker Auto
Previous forum rides:
XH Falcon Ute 4.0 Auto
BF XR8 5.4 Manual
'88 60 Series Landcruiser Turbo Diesel.
Komatsu 830E Haul Pac- 2500hp, 165tonnes.
AUIII XR6 HP: Prepared by Aussie Car Enhancements & Custom Tuned by Blue Power to a record setting 14.22@96mph.
BA Fairmont Ghia 5.4 3V :Unfinished business.
Tri Power 289 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2006, 10:44 AM   #9
alpineau
alpineau's Avatar
Hope it helps.
Thanks Tri Power, It seems that it might be something to do with the fuel pump or filter and after reading how hard a new one is to install i might just take it back to the dealer. :(. I was trying to avoid that becuase the only time they can get it in is the day my car goes to get the bodykit fitted. Owell i guess the pump will have to wait to i get the car back.
Alpineau
