Old 17-07-2006, 11:06 PM   #1
Cooper69S
Cooper69S's Avatar
Default rattly when cold
gday all... my AUII forte v8 seems very rattly when its cold. I've only had the car 3 weeks... my EF I6 used to have the same sort of symptoms but they only lasted for a few seconds after starting the car. The AU seems to take quite a while (up to several minutes) before it quietens down - seems to last almost until its up to normal running temp. I just did an oil change but that didn't seem to make any difference. its only done 135000km so i wouldn't have thought it would be a wear problem - unless the cops really wore it out when they owned it...?? any thoughts?
thanks
Geoff
Cooper69S is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2006, 01:38 AM   #2
JC
JC's Avatar
Is it a rattle, or more like a ticking noise? Does it increase with revs, or decrease? If it's an increasing in sound ticking, then it could be loose exhaust manifold, or blown/torn manifold gaskets.
Ford Performance Club ACT
Old 18-07-2006, 10:14 AM   #3
Papa Smurf
Papa Smurf's Avatar
Cooper69s, what sort of Oil Filter did you use? some of the CHEAP ones have no non-retunr valve and when you start the car, the oil pump has to prime. Ryco ones used to be like that. Old holden motors were a classic for that.
If you DID use a good filter then I would be checking the Oil pump and drive?
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2006, 01:58 PM   #4
Cooper69S
Cooper69S's Avatar
i used a valvoline filter - they ok? It does sound more like an oil problem to me than a manifold/gasked problem - its just a generally noisy engine until it warms up then its fine (until that solenoid ticking starts)
Old 18-07-2006, 05:40 PM   #5
bodes-sh
when i had my ea i6 it did it a fair bit as well for a while, i tried some nulon lifter free and tune up, that made it a lot better. I think supercheap sells it for about $10 - $15 a bottle. it basically cleans all the old oil and crap out of the lifters...as the name states...
Old 18-07-2006, 07:23 PM   #6
OzJavelin
OzJavelin's Avatar
thanks
Geoff
My AU V8 has only done 120,000km .. has been regularly serviced .. always had anything fixed in a timely fashion .. and it's got serious problems. Most likely gudgeon-pin noise .. which started about 10,000km ago like the noise you are describing. Windsors are not the dependable rock I hoped they were.
Sorry to be a gloom-and-doom merchant. I hope you find your problem and it's a simple fix!
Rod.
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2006, 07:43 PM   #7
Cooper69S
Cooper69S's Avatar
i'm not entirely sure what gudgeon pin noise would sound like... it probably sounds more like lifter noise to me - i'll grab some of that nulon stuff and see if it makes a difference... can't hurt i spose...
thanks
G
Old 18-07-2006, 09:50 PM   #8
JC
JC's Avatar
One engine does not mean all Windsors are not dependable. Mine has done 150k and (touch wood) is still going strong. It's not like it's a Gen3 with major oil burning issues.
Old 18-07-2006, 09:59 PM   #9
sednwol
sednwol's Avatar
At least there is a known fix for that.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2006, 07:31 AM   #10
OzJavelin
OzJavelin's Avatar
Yep I agreed .. but as far as I can tell the last of the 5.0s in Oz were a bit of a hit-and-miss affair as they were stockpiled after Explorer production ceased. Some of our "issues" could be related to this; Tickford engines excempted .. ?
Most "older" engines I have dealt with - eg. 327 Chevs (x2), 318 Chryslers (x numerous), 383 Chrysler (x1), 351C (x3), 343 AMC (x1), 360 AMC (x1) etc - have managed to thru 100,000miles without any major mechanical problems (AFAIK) .. and typically with a fair degree of neglect in their later lives. If my 5.0L gets to 160,000km I'd be very surprised.
Had that too .. I suppose I'm just lucky! But In my case the engine decided to misbehave INSIDE warranty, not 20,000km OUTSIDE it like my AU :(
Anyway, if this is a lifter problem then hopefully that's not a big issue. Kepp us informed.
Rod.
