26-06-2006, 10:34 AM | #1 | ||
Could any of the drag gurus help me out please.
Both MT ET Street 16" and 17" tyres will fit my BA, which should I choose and why? Or does it not matter? I have a standard diff atm, which is likely to change in the next 6 months. Standard brakes. I need to improve my 2.3 60fts ;-) Thanks.
2007 BF Typhoon 11.79@117 Last edited by Des Flurane; 26-06-2006 at 11:11 AM. |
26-06-2006, 01:39 PM | #2 | ||
KITTY Crew Member
Someone told me just yesterday (and he is a drag racer), while we were talking tyres. That you should get the biggest tyres you can, even if you have to sacrifice some width for diameter..
But this may be wrong. I am still learning
FOR SALE BAII Super Pursuit 0083 Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
26-06-2006, 01:46 PM | #3 | ||
Depends on what your trying to do. By that I mean are your trying to 60 faster or obtain a higher top speed. The taller tyre will have a higher top speed but will impact on your 60's. The smaller tyre will help the 60's but won't help top speed. Smaller tyre can make a 3.45 diff act like a 3.5/3.6:1 ratio. A taller tyre might make a 3.45 diff react like a 3.2/3.3:1 ratio. You can get some quite tall tyres which I have no doubt would make a 3.45 ratio effectively a 3.0:1 ratio.
Most like myself just come up with a happy medium. Although I'm going to try a 28" tall tyre on a 15" rim next. I've currently got a 26" tall tyre on a 16" rim.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
26-06-2006, 02:35 PM | #4 | ||
Now I'm confused?
I will be getting more power with the installation of my headers today and a custom tune this Thursday, so I guess it's the 60' time Im needing at the moment, as traction seems to be an issue on the track I run, Meremere, Auckland. The 275 is about the same diameter and the 255 a 1% increase. Not really much to choose there. Would the higher profile on the 16" of 50 give better performance? What does everyone else run on there BAs?
2007 BF Typhoon 11.79@117 |
26-06-2006, 04:25 PM | #5 | ||
mate have you tried just letting some air out of your standard tyres.say drop them down to about 20 /22 psi.
26-06-2006, 05:26 PM | #6 | ||
Weezland
A larger sidewall will give more grip, 60 as opposed to 50 in equal widths, but unless you have the right gear ratio a tall tyre can bog the car and hurt your top end a little by not letting you use your top gear fully.
I am in this situation and use a 26" tyre. even with that I cross the line at 900rpm under what I should, a 28" tyre will make this worse. |
26-06-2006, 05:47 PM | #7 | |||
Location: Working, chasing after my daughter and working
26-06-2006, 06:41 PM | #8 | |||
AFF.com.au
a large tyre will eat kilowwatts for brekky. the best tyre for your application is a 255/16 MT ET street on a widened 16"stock rim. start it at 26lbs, and drop it in 2lb increments till the wheelspin stops. Good luck mate and have fun! |
26-06-2006, 07:26 PM | #9 | ||
Thanks Chris.
