Old 08-06-2006, 11:29 AM   #1
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Question Question about the Dash/Cluster ... help please.
Hi guys , Since i bought my car i have has a small white moth stuck behind the clear plastic on the dash/cluster just next to the DTE display.
Before i go trying to pull things apart and probably wreck something , i thougt i would ask first how to remove the plastic cover , as im sure someone here has done it before . Any advice appreciated , cheers ;) .
:eclipsee_
Old 08-06-2006, 12:18 PM   #2
XR6-VCT-2000
Fantastic Plastic
is it just those 2 small lugs you remove , at the top of the dash/cluster on the outer side of the clear plastic ?
:eclipsee_
Old 08-06-2006, 12:28 PM   #3
LG
LG's Avatar
Here you go
http://www.aufalcon.com/Tech/techinstrument.htm
They are fairly easy to break/snap... Good thing is that you can buy the parts from Ford, cheap. The plastic screen is only $20.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 12:36 PM   #4
XR6-VCT-2000
Fantastic Plastic
Originally Posted by LG
Here you go
Cheers LG ;) .
:eclipsee_
Old 08-06-2006, 01:47 PM   #5
XR6-VCT-2000
Fantastic Plastic
WOW ! , that was too easy , i was expecting a bit more drama than that, thanks again.
:eclipsee_
Old 08-06-2006, 02:26 PM   #6
ziggee
speaking of which, yesterday night, my DTE area went all dim.... but the odo is still bright? what gives there? is it a led problem? as the DTE is still visible just not as bright as the other 1/2 hmmmm damm it annoys me....
Old 08-06-2006, 02:39 PM   #7
XR6-VCT-2000
Fantastic Plastic
Allthough i havent really looked at the setup on the back of the cluster , most black/grey didgit lcd's use cathodes to light them up , probably whats happened , blown a cathode or an led probably .
:eclipsee_
Old 08-06-2006, 02:47 PM   #8
JC
JC's Avatar
There's 2 little light globes that light up the LCD display - one of them will have blown.
Ford Performance Club ACT
Old 08-06-2006, 06:39 PM   #9
ziggee
cheers
Bugger! so can I just do what has been suggested in here and remove the cluster and replace it.. which I assume is screws and then whatever...
saw a write up on it by someone ine here, in fact I think it was JC!
