Old 13-05-2006, 08:11 PM   #1
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
Cool new engine jerks just above idle??
Just had a VCT engine installed into my AU and now it feels like Im flying an F16 fighter jet compared to the sluggish 800thou+km engine which was in it, but there is one annoying thing it does now which bugs me (its also just been converted from auto to manual)
when im driving at a constant speed with my foot slightly on the throttle, the engine jerks like it doesnt know if its supposed to be injecting fuel or not......
If I put my foot down a bit more its fine or if I take my foot of its fine too, its only when im trying to maintain a constant speed. the lower the gear, the more noticable the jerking (thats probably because the higher gears absorb the jerk)
Is this normal??? could it just be the computer needs time to relearn itself?? Any ideas what the problem could be??? cheers.
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2006, 10:11 PM   #2
SIKSIX
Its gone V
SIKSIX's Avatar
This is sorta out of no where but maybe check that the engine mounts are doing thier job.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2006, 11:12 PM   #3
onfire
onfire's Avatar
Iv noticed my AU1 4.0l does that. I actully read on here somewhere, to drop it back into third. When say cruising in a straight line through suburban streets under 50km/h. Try that.
FOR SALE: 2 0 0 3 F A L C O N X R 8
http://www.fordforums.com.au/showthr...31#post5041431
onfire is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2006, 10:47 AM   #4
Stav
Smile
Stav's Avatar
Mine does that gently with the auto..I am thinking it may be the tps readings at light pressure arent registering right.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 14-05-2006, 11:12 AM   #5
RG
Back to Le Frenchy
RG's Avatar
Sounds like backlash, most do it, especially manuals.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2006, 11:41 AM   #6
robbo_yobbo
Kick out tha Jams
What is this? any way to stop it or at least minimise it?
I did notice that too, but I had to be in 4th at 60kph to reduce it if i have light pedal pressure
This sounds like the sort of problem I thought it could be, next problem, where to from here???
Its litteraly like when im just lightly touching the pedal, the car gives the engine fuel, and then decides its too much so stops all together, then decides it needs more fuel so gives it another quick burst, and then stops again and so on and so on....
its almost as though its not capable of injecting a minimal dose of fuel, so just gives it larger doses inconsistantly..... could it be a fuel map issue even, or am I barking up the wrong tree?
Old 14-05-2006, 11:44 AM   #7
Stav
Smile
Stav's Avatar
I dont know man.Ive noticed more since ive been told to drive my new box in economy mode.Not so much in power.But power wrecks my box.
Old 14-05-2006, 11:49 AM   #8
RG
Back to Le Frenchy
RG's Avatar
You would have to talk to a driveline specialist about that one.
Old 14-05-2006, 12:03 PM   #9
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
I have exactelly the same problem in mine (but mine is an auto), and i dont think its a problem ! - it just the revs are too low to push the car along imo , mine does it if in 4th and slugging along slowly around 60kmph . Years ago I put a 4 speed auto from a mustang into my old XE ( was a carby driven car too , not fuel injected - no ecu etc etc ) , and it did exactelly the same thing in 4th in my XE too if i drove it in 4th around 60kmph (that auto was almost identicle to these auto's too, the ford FIOD 4 speed auto )- imo it's almost like trying to push the car around on idle !. Personally in that car - and this 1 - i didn't/don't use 3rd unless on hwy's etc etc unless im doing around 100kmph .
:eclipsee_
XR6-VCT-2000 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2006, 06:36 PM   #10
XR6-VCT-2000
Fantastic Plastic
Ooops , typo error - 4th gear i meant sorry .
:eclipsee_
Old 14-05-2006, 08:40 PM   #11
robbo_yobbo
Kick out tha Jams
I dont have the problem in 4th and 5th as the higher gears absorb the jerking, its only predominant in 2nd and 3rd (im sure it would be the same in 1st if I tried to keep a constant speed too), the lower the gear, the more noticable it is.
Old 14-05-2006, 11:19 PM   #12
XR6-VCT-2000
Fantastic Plastic
Oh i got ya , sorry , it could be as GreenEL stated then ! .
:eclipsee_
