#31 | |||
Regarding the timing, it was fine before i started working on the intake manifold. i can't see how the intake manifold and injector removable can offset the timing. If it is a timing chain issue, then it's an amazing coincidence a bad chain causing to mess up the timing on the next start after. But hey..... those odds of such a coincidence to happen to me is likely. I am that cursed. By the way, if timing was off, surely i would get a number of codes. But i will check it out anyway and thanks for your tips. Last edited by JustBill; 05-08-2024 at 10:25 AM. |
#32 | ||
Slight mistiming generally gives a cam sensor fault, leading the novice to replace that sensor.
Testing for firing with another fuel (or even a splash of diesel into the intake) is a good way to see if the mechanical aspects of a motor are sound. |
#33 | |||
Still not getting the full 12v power into the sensor which is strange but getting the 5v from the signal wire which is supposed to. To verify timing, i will check and lineup flywheel with the pinning hole. If i do that, would i also need to remove the timing belt cover and check that the camshaft and crank all lineup aswell? So it's virtually doing a timing belt change without placing a new belt? |
#34 | ||
It’s not a two minute exercise, no. Less effort than changing the belt, though.
#35 | |||
It also used to kill them every 12 months until I MacGyvered in a massive DIN85L sized battery. You got a battery charger? Put it on the car overnight and then try start in the morning and see how you go. Also check condition of main earth cable, on the Focus its on the passenger side shock tower, unsure on Mondeo but could be similar as they share a platform. |
#36 | |||
I'm starting to believe i have a timing issue which i'm going to need a new belt. **** me how did i get myself in this mess. Just learnt from Alan Howatt in one of his videos, that the high pressure fuel pump needs to ne timed also with the power train timing. If the timing is out with the fuel pump you don't get the injector spray in sinc. Maybe that was the original cause of loss in power. Last edited by JustBill; 05-08-2024 at 08:58 PM. |
#37 | |||
![]() They needed to get some specialist in to get the snapped thread out of the crankshaft, which took him all day. Be prepared for a fun* time *will not be the usual definition of fun If you got good quality jumper leads, get another car onto it, but go to the negative terminal on the Mondeo, not the Mondeo body earth as its not big enough to get enough current through to turn over diesel engine fast enough to get it to fire. If its like the Focus its a pain in the *** because the negative terminal sits under the wiper cowl, might need to take off the wiper cowl to get enough clearance. How good are European cars? |
#38 | |||
Re timing, i'm just going to check if the timing is ok and adjust it if need then retention the same belt, thats if the belt is one piece. So i wont need to unbolt the balancer pully. Last edited by JustBill; 05-08-2024 at 10:42 PM. |
#39 | ||
Update:
* I opened the timing case and found the belt intact. * Then i checked if the timing was accurate. * Locked the flywheel through the hole behind the starter motor. It definitely went in as the crank wheel could not spin (due to the pin locking the fly wheel) * Checked if the hole on the cam cogl lined up with the hole on the back which is about 4 o'clock. Low and behold..... the hole on the cam cog was facing 2'oclock * Removed the belt from the cam cog, with the fly wheel locked into place, turned that cam cog from 2 o'clock to 4 o'clock where the 2 holes lined up so i can put the bolt through it. *then put the timing belt on. Now going to put the pieces back together again and see how it goes. Question... How is it possible for the timing to go off with the belt not snapped and still teath on the belt? Why i ask is can it happen again. |
#40 | ||
The crank sprocket is “slip and grip” (my description, not the official term). It relies on that massive torque of the centre bolt to provide clamping force that holds the sprocket in position. When you’re breaking or tightening this bolt, it’s necessary to use a counterholding tool - not to rely on the crank timing rod for you use for checking.
Perhaps the bolt wasn’t tight enough and that’s how you slowly got out of time. |
#41 | |||
#42 | |||
#43 | ||
On the positive side, it sounds like you’ve possibly diagnosed the root cause.
If the crank is located and locked correctly per the pin in rear of flywheel, and your belt driven cam is correctly timed, it doesn’t matter where the lower sprocket and belt are when you tighten the centre bolt. It’s just got to be insanely tight. Peugeot say 70Nm +60°, it’s a single use bolt. Use the old one to make a chasing tool and clean the crank nose threads. |
#44 | |||
#45 | ||
You’re too kind. I try to help when I can see someone is making a serious effort themselves.
Hopefully you’re close to a solution, counterholding the ring gear while you lock that bolt down super tight, will be a decent challenge. |
#46 | ||
I will do it in reverse to when i loosened the bolt. Used the breaker bar and added a 1 meter steel pole as an extension then used both arms to lift. I will also add thread loctite glue to the bolt. Then good luck to anyone needing to take it off again in future.
#48 | ||
I've just caught up with this thread... Hope you get it sorted. Does the service history show whether the cambelt has been replaced recently?
Sent from my SM-S906E using Tapatalk
#49 | |||
I've sorted the timing and closed it all up then crossed my fingers. Still won't start. So i've taken it to a fourth mechanic. Now he tells me something completely different from the other 3. It's the worst case off all. He said the engine is knackered. He said no compression when turning over. Although, i'm no mechanic but i don't believe him. Because without he giving me specifics why the engine is gone, A) the crank wheel spins therefore isn't seized, B) When the cam wheel spins you can hear the suction sound i assume the piston make and i can feel the tightness then release together with the suction sound when spun at particular points. If he is right..... Then i hope its just the rockers are damaged because i'm confident in changing them myself. Apparently the engines on these Mondeo's are designed for the rockers to give way so the pistons survive if a timing belts or chain snaps. This has became a nightmare now. I've gone so far (New timing belt + tensioner, Injector seals, intake seals and intake holes cleaned, new transmission fluid and filter, new engine oil and filter, injectors tested and cleaned, new leek off pipe) and am stuffed to know if i should just stop and scrap it or keep fighting. I'm interested to know if my description as to why i feel the engine is fine and that i could be right or wrong. Big job getting to the rockers then only to find out nothing wrong with the rockers and tappets. Last edited by JustBill; 17-08-2024 at 05:44 PM. |
#50 | ||
I was trying to understand how the timing could be that far out and thought perhaps the cambelt had been changed and the timing not set properly?
No compression sounds terminal though. Sent from my SM-S906E using Tapatalk
#51 | ||
Diesel Sniffer
When u first described how far out the cam gear was I wondered if a valve had meet with a piston,if so as u say I'm also lead to believe that the rockers are the weak link(but that's just hear say on my behalf as I have no concrete evidence to support it) so u may well have a few broken rocker arms, so it's either pull the rocker cover & check or pull the glow plugs(or injectors-depending on the tool & give it a compression check-have any of these so called mechanics given it a compression check or cylinder leak down check?....if not I'd be asking how they came to all these wonderful diagnosis without knowing the true health of the engine & each & every cylinder in that engine.....) also be aware that a diesel will produce a lot more compression than a petrol ,so u need a tool for a diesel(which will also have the relevant adapters be it injector or glow plugs).....not sure were u are but if u are in Sydney I can load u a compression test kit for a diesel.....but also as suggested, pull the air intake off at the manifold & give it a sniff of starter aid & see what it does(don't use that crap start u bastard or aero start-they are the best way to damage an engine....yes seen it many times, all i use is inox or wd40 its flammable enough to induce starting without causing damage) but in all reality your best choice is pull the rocker cover & take a look, if still not 100% have someone wind the engine by hand while u watch the valve train..... I wouldn't give up I don't think u are far off getting this car going..
#52 | |||
I'm in Melbourne. By the way i'm 55 years old and am starting to feel my health both physical and mental suffering because of this Mondeo. Not good. I'm just starting to convince myself it's not going to be the end of the world if i just somehow pay my son back his money and apologies. He will refuse accepting my money but that will mess with my mind more knowing he has a good heart and i cost him his money. I got myself a dozen rockers this morning. And...... 2 cam position sensors. You know what? not one of the 4 mechanics suggested try a different cam sensor even though the computer says "Problem with the cam sensor". Not even i thought of it (well i did but thought surely the mechanic would have suggested it). I will lolololol if it was that simple and obvious (no i wont instead i will shake my head) but be relieved and start doing cartwheels. I drove the car 2 weeks with no engine lights or codes at all. This code P0340 camshaft positions sensor "A" never happened until on the way home after picking the car up from the 2nd mechanic. Don't know if they touched something and didn't put back the way its supposed to or it's just a total coincidence. But even then the car would start instantly. This non start and with a new code P0087 fuel rail system pressure didn't happen till after i changed the intake manifold gaskets. so doubt it has anything to do with cam sensor code. Last edited by JustBill; 18-08-2024 at 04:23 PM. |
#53 | |||
It doesn't say 'cam timing', just 'camshaft position sensor' which leads to people throwing camshaft position sensors at it and having the same problem ![]() Wonder if your camshaft sensor code was an early warning about the timing being out because of the belt slipping out of position. |
#54 | |||
#55 | ||
Diesel Sniffer
No if u had the crankshaft pinned by the flywheel & the camshaft pinned,then it is correct(unless it was not pinned on number 1tdc - so even to verify that u will still need rocker cover removed & re-pin the engine & verify that it's correct by looking at the valves#No4 rocking No1 free)the only way the crankshaft could move independently of the flywheel is if the crankshaft was broken. I'd more suspect broken rocker arms
