Old 13-04-2024, 06:45 AM   #31
None-ya
Default Re: Why so few old Falcons remaining compared to Commodores?
Originally Posted by Franco Cozzo View Post
Everyone is wrong, we all know its because the superior engine option of the mighty 3.8L Ecotec V6
Had this old bloke customer with a VN wagon come into my workshop for a rear wiper motor, things odometer stopped working at 727,000km, this was in 2015.
The guy had been all around Australia in it with his family, had done two gearboxes and still on its original Buick V6, the predecessor to the mighty Ecotec, I reckon he's probably pushing up daisies now he was old AF back then, VN wagon is still probably going.
Mang till ya bang, or just randomly bang going down th highway, or apon (?) Start up at under 70k.
All people have the right to stupedity but some people abuse the privilege
None-ya is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2024, 06:59 AM   #32
None-ya
Id say rusty killed alot, head gaskets would have killed some more, scrap'ies (never looks right however I spell it lol) would have killed a few, young roster heads followed by 'power junkies ' ( if it lets me say it )
Old 13-04-2024, 03:44 PM   #33
My32Doors
https://www.msn.com/en-au/news/austr...bedeaf66&ei=46
My32Doors is online now   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 06:12 PM   #34
Sprintey
Sprintey's Avatar
What a good article, they know about comfort, , simplicity, reliability and common parts!
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 07:01 PM   #35
mick taylor
Originally Posted by Dr Terry View Post
VB to VL rusted as bad as Falcon XF-EL, although not quite as bad as XD-XE.
Holden changed their assembly procedures at VN & from then onwards were markedly better in the rust department than the equivalent Ford.
Find any VN-VS these days, it might have dead trim & some of the electrics & mechanicals, but their bodies do seem have stood the test of time. Have a look in wrecking yards, it's quite noticeable.
You're are correct about the enthusiast market, Ford took a 10-12 year break from anything remotely resembling a performance car, while HDT & HSV had a field day. This shows up in desirability & resale values of cars of that era.
Dr Terry
The biggest rust buckets were the XA-B-C Falcons shocking even from new such was starting.
I thought from VB Commodore they were using a much better steel, only the windscreen became a problem area after the old one was pulled out and took the paint off, then the problems kicked off !
Then again back in the 1960's to say 1980 we had highways that were the type that you had to get 2 wheels off onto the dirt when a car came the other way, so the left side coped a lot of mud etc and many % people did not bother to wash their cars well or parked them outside.
More Dirt roads as well years ago and dirt gets in the bottom of the doors and then rain and due from sitting out side makes more rust and the bottom of the doors would block up, i would have to poke a stick up the drain holes many a time as you would hear water splashing when shutting the door.
Look at how wide the roads are now ! no chipped windscreen once a month anymore nowadays.
I just believe that people back from before 1990's did not look after a car as well as some do nowadays.
I think more people have learnt to look after their car nowadays because you have to Radiator coolant for one or else ! many more know this nowadays ! before such was no an issue !
So i hear people claim that the VL 3.0L was a crap engine ? i reject that and put such down to not servicing them correctly and not bleeding the radiator is a big mistake many made.
Falcons got better with rust from XD on and were the much the same to the end, maybe a bit better.
But i believe that the steel from 1972 to 77 with ford and Valiant was that Holden got first dibs regarding steel and Ford came 2ed but had to import some times and Valiant's came 3rd so they had to get steel imported at times and this was old crap steel that was melted down to make new steel, but within this was small % of rust that was within the brew, even tho they had skimmed off all of the crud from the top ! Am i correct for them years, maybe they got the art work better regards such. The VB Commodores got a new formula for steel they claim and coating and a smash repair dude i know well said that welding this steel was harder than before.
mick taylor is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 08:29 PM   #36
fatgas
Purveyor of fine filth
Ford never really sorted their panel prep and paint processes in Australia, whereas Holden to their credit pulled the digit out with VN and they didn't look back. The only Commodores VN and newer I see that are rusting are the ones that are poorly repaired after a shunt.
fatgas is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2024, 03:26 PM   #37
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Up until VN production Holden only dipped the bodies to the waist line and because they went through the dip on a conveyor the wave and wake created a void around the rear windscreen base which rusted out, this processed changed with VN and the whole body was dipped.
Falcond prior to EA were prone to rust in the plenum which would flood the front floors and required substantial work to repair in removing windscreen, dash, gaurds, bonnet and then cut open.
I had a beautiful XE in 2000 but couldnt take it out in winter for this reason.
Obviously E series suffered head gasket issues that really affected not only daily driven cars but limited the used engines available in wreckers too.
The funny thing is, they fixed that in AU and wreckers couldnt give them away.
I spoke to a mate who owned a used car yard back in 07 and he said every manual Falcon he could get his hands on went up north to indigenous communities as they loved them and paid way overs to what could be sold for down here, he said lots of yards did the same. Probably plenty still active albeit unregistered.
I got a nice XE S pak off him that day as it was auto and worth nothing, gave it a straight gas conversion and sold it to a FF member.
So there are a few factors at play.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2024, 04:42 PM   #38
None-ya
Forgot to mention taxis
Old 17-04-2024, 02:45 PM   #39
mick taylor
Yes they play cards in the headlights until the battery goes flat, then push start the car the next day. so automatic cars are not wanted out back by them at all.
Old 17-04-2024, 02:46 PM   #40
XR Martin
XR Martin's Avatar
Regarding XF/XG/XH utes not surviving compared to Holden utes, remember that the Falcons have always been used for work, where the Commodores have usually been for play.
Holden even tried a 1 tonner VZ and I think they only sold a few hundred.
Sure they rusted but I've been through heaps of wreckers and rarely did I see one scrapped solely due to rust.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 17-04-2024, 04:42 PM   #41
Dr Terry
I think you'll find that the VG-VS Utes were used much more as a workhorse than the later VU-VZ versions because the latter had IRS, while the early ones had a live rear axle.
They made 1 Tonners in both VY & VZ & they sold many 1,000s in 2WD, but the AWD version was VZ only & it sold in much smaller numbers.
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2024, 04:40 PM   #42
roKWiz
Cabover nut
roKWiz's Avatar
Some still are.
Genset and granite to Beechworth today 4 new tyres on the way home.
Old 19-04-2024, 07:42 PM   #43
janddbone
B1 - J & D Services
janddbone's Avatar
Do not discount the thousands of Falcons used as race cars over the years having a significant effect.
Mr. Brett Johnstone.
2007 Honda Odyssey
2002 Ford Laser
2000 Ford Falcon Wagon Egas
1999 Subaru Imprezza Sportwagon
1998 Holden Suburban 2500
1995 Land Rover Discovery TDI
1994 XG XR6 Longreach
1983 Holden Rodeo
1982 ZK Fairlane 302 six seater
1975 Datsun 120Y wagon
1970 MG Midget
1967 Rover 2000TC
Soon: Model T.
janddbone is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2024, 08:50 PM   #44
MrZ
MrZ's Avatar
Hmm, considering Ford sold around 70-80,000 Falcons per year in the late 90s, I'm not sure if a few thousands of those used for racing would have much effect.
Maybe the fact that the Falcons were used as taxis while the Commodores weren't might have some effect.
MrZ is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2024, 09:02 AM   #45
roKWiz
Cabover nut
roKWiz's Avatar
There's not to many HQ Holden sedans left thanks to the HQ racing series.
Old 20-04-2024, 10:42 AM   #46
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
They actually made 467,558 HQ's, it was the best selling model Holden ever made, the next closest was the EH with 256,959, I still see a fair few good HQ's around
Old 20-04-2024, 11:46 AM   #47
Itsme
Experienced Member
Itsme's Avatar
Correct, I still see plenty of HQ's getting around, not bad since they were considered a rust bucket.
Old 20-04-2024, 01:29 PM   #48
jpd80
jpd80's Avatar
In some instances, scrapping a vehicle that’s become unroadworthy may yield more in return than trying to fix it.
I remember seeing a 2020 price of $6,600 for rebuilding ZF6HP. and think it must surely be more now…
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2024, 01:36 PM   #49
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Same with Hyundai Excels, when was the last time someone saw one of those things? The excel racing series took them all from us
Saw there's a Mazda RX8 racing series, thats the next nugget car thats going to completely disappear - those things would be stacked 10 high at the tip otherwise.
Only thing they're good for is LS conversions.
Old 20-04-2024, 02:28 PM   #50
XR Martin
XR Martin's Avatar
G8 220 and in the same carpark a DC LTD - both well looked after.
Yesterday a burgundy EL XR6.
Day before a unrestored XB GS. (See it occasionally getting around)
There's also an old duck getting around in unrestored ZK Fairlane near me.
Old 20-04-2024, 02:29 PM   #51
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
No great loss
Old 20-04-2024, 02:38 PM   #52
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
That and speedway, juniors car of choice at the moment.
Before the Excels it was the Daihatsu Charade, when I had my GTti race car the only way to get parts was to buy whole cars, even then you had to be quick, the speedway guys were buying up and hoarding everything.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 21-04-2024, 01:23 PM   #53
Dr Terry
I believe that the VE Commodores surpassed the HQs build total. I don't have exact figures, but around 350,000 were sold in Australia with another 170,000 exported. That's approximately 520,000 in total.
Dr Terry
Old 21-04-2024, 04:02 PM   #54
There are a few different figures around on Holden build numbers. Drive and News seem to agree on the HQ as the biggest selling Holden and the VT as the biggest selling Commodore.
Drive said:
“485,650: The biggest selling Holden of all time, the HQ Kingswood, made from 1971 to 1974.
303,895: The biggest selling Commodore of all time, the VT series, made from 1997 to 2000.
https://www.drive.com.au/news/holden...ws-since-1948/
News said: “The VT was the biggest selling Commodore model of all time, with a staggering 303,895 built over almost three years. However, that’s still not as high as the HQ Kingswood (485,650) in the 1970s.”
https://www.news.com.au/technology/i...73e59e92554186
Carsguide offered this opinion as to why the VT was so successful: “ It also helped that the Falcon of the day was regarded as ugly, prompting buyers to flock to the Commodore in droves.”
https://www.carsguide.com.au/car-new...he-years-35814
2017 ZG Escape Trend AWD 2.0L Ecoboost
Old 21-04-2024, 05:11 PM   #55
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Dr Terry
I didn't include the Commodore as its origins were European, but yes they made a lot of VE's
I think most Holden figures are what were sold in Australia, they sold knock down kits to South Africa too
Old 21-04-2024, 10:21 PM   #56
portokatsiki
Yesterday I went for a drive from Melbourne to Echuca and back. I saw no less than 8 AU falcons/fairmonts in aii body variants. I only saw 1 vy commodore. AUs have certainly outlasted by miles the same era commodores.
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2024, 11:14 PM   #57
asagaai
asagaai's Avatar
A year ago I drove out to Narrabri to go to Mt Kaputar and the number of Falcons in the country outnumbered Commodores like 4 to 1.
And the Falcons were in good condition, a lot of FG series I saw.
Ford Rides:
Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K
FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender
asagaai is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2024, 08:25 AM   #58
roKWiz
Cabover nut
roKWiz's Avatar
There's still a good supply of HQ utes and tonners (occasional wagon, Monaro's and Statesman) getting around but not so much of the Belmont/Kingswood sedan variety.
Old 22-04-2024, 08:51 AM   #59
Dr Terry
Not so !
While Earlier Commodores were European based to varying degrees, by the time you get to VE, the body/chassis is 100% Aussie designed & built. The drivetrains are mostly US units. I doubt that you would find anything Euro in a VE or VF.
Much like the Falcon, early ones were very US-based Then less so by XA & even less so by XF. EA onwards doesn't have much US left in in them. AU onwards nothing left.
Also all Holden build figures include all overseas built units, because they were CKD packs. The packs were made here then exported & they knew the exact numbers.
Dr Terry
Old 22-04-2024, 08:54 AM   #60
I thought big end bearings on the Falcon sixes remained a constant?
As to the VE, weren’t the locks (Huf) a German company?
Apple, Table… something!
