Old 27-04-2006, 09:37 PM   #1
GraveDilute
GraveDilute's Avatar
Default VSS & Reverse signal location
Where would I find these signals?
What colours are the wires?
I'm going to install an aftermarket navi.
I want to put it in my BA but it seems technically challenging.
Hopefully can easily put in the AU.
GraveDilute is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2006, 09:53 PM   #2
AUXRVIII
What model & what location do you want to tap into the wiring?
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 03:01 PM   #3
GraveDilute
I want to put it into a series 1.
The navi will go into the existing stereo location (doesn't need external discs, or anything), so I would tap into signals as close to cluster as possible.
Old 28-04-2006, 03:08 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
VSS should be a white wire.
Reverse cant remember dont have a diagram with me
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 06:20 PM   #5
TwistedEL
TwistedEL's Avatar
I don't think there is a reverse wire is there? The cluster / ecu know the gear based on the resistance coming from the inhibitor switch.
Might need to make a circuit to test the voltage on that wire, or hook it into the reverse lamps (probably not the best idea)
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2006, 12:19 PM   #6
GraveDilute
Any info guys?
Old 01-05-2006, 12:29 PM   #7
Laminge
Cuban... nothing like it
http://www.fordforums.com.au/photos/...ry.php?cat=660
See if that helps
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
