Old 25-05-2023, 11:00 AM   #1
avisionit
AU-XR8-302
Default Au XR S3 Tickford Cluster Plastic Cover...
Does anyone know if the standard Falcon/Fairmont Perspects instrument cover is the same as the Tickford plastic covers???
My cluster is fine, but all the plastic clips on the perspects are broken. Its cheap to buy a standard cluster and replace the plastic cover if they are interchangable?
Tony.
avisionit is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2023, 11:19 AM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: Au XR S3 Tickford Cluster Plastic Cover...
The perspex cover will fit in terms of fitting over the cluster itself.
The problem you run into will be the odometer reset button is positioned differently.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 25-05-2023, 11:22 AM   #3
avisionit
AU-XR8-302
OH, thats a point. Didnt think of that... Thank you.
Old 25-05-2023, 12:14 PM   #4
fordomatic
fordomatic's Avatar
Fairmont Ghia and Fairlane Ghia plastic cover will fit tickford cluster. Anything else won't as per what PG2 said.
Proud owner of the ugliest Ford ever made
fordomatic is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2023, 12:24 PM   #5
avisionit
AU-XR8-302
Smile Re: Au XR S3 Tickford Cluster Plastic Cover...
Thanks for adding that because I was just about to ask. There is a fairmont one on Ebay for 90 bucks reckons the taps are in tact so that works for me..
Thank you.
