Old 14-03-2021, 06:46 PM   #1
Skwirls
Default LT TDCi front rotors size
Can anyone enlighten me what size rotors are supposed to be for the LT '07 Diesel? Also are the pads DB1679?
The workshop manual (available here) says its 300mm but every eBay or other online listing is saying its 278mm, confused
Skwirls is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2021, 09:03 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: LT TDCi front rotors size
278mm is the size for the 1.6 and 1.8L engine models according to the LT WSM.
I believe the pads are DB1679 for the front and DB1763 rear.
The replacement front rotor should be a Bosch PBR2380 or DBA 2118E.
Observatio Facta Rotae
Old 15-03-2021, 09:22 AM   #3
GTLEGEND
Below are the specs for the brakes, how ever its confusing as the parts catalogue only lists one rotor for all?
Genuine Rotor: 5M512C375AC
Genuine Pads: 7M592K021AA
Old 15-03-2021, 11:55 AM   #4
Skwirls
Attachment 104118
Yep exactly, the DBA2118E is a 278. I thought the diesel was supposed to have larger rotors, I guess I'll have to pull one and measure it
Old 15-03-2021, 12:02 PM   #5
GTLEGEND
I would like to check something, would you be able to supply your VIN..
Old 15-03-2021, 12:23 PM   #6
Skwirls
Originally Posted by gtlegend View Post
i would like to check something, would you be able to supply your vin..
afadxxmjdd7y00722
Old 17-03-2021, 08:16 PM   #7
brucewarring
I am confused also I have a LS 2ltr Ghia sedan made in South africa and every thing is different including LHD headlights could you please let me know what front and rear disc rotors I should buy I get told 278 all round and also get ones that fit thanks
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2021, 09:19 AM   #8
marg99
I had a LT tdci made in South Africa and it had the 278 rotors
Old 18-03-2021, 10:20 AM   #9
russellw
russellw's Avatar
LR Front
300 mm – vehicles with 2.0L Duratec ST
258 mm – all others
LR Rear
280 mm – vehicles with 2.0L Duratec ST
252.7 mm – all others
Some LS/LT models were equipped with 203 mm drum brakes on the rear.
LS/LT/LV Front
300 mm – vehicles with 2.0L petrol engine or 1.6L/2.0L diesel
278 mm – vehicles with 1.6L/1.8L petrol engine
320 mm - LV Focus 2.5L Duratec-ST only
336 mm - LV Focus 2.5L Duratec-RS only
LS/LT/LV Rear
280 mm – vehicles with 1.6L diesel, 1.8L diesel or 2.0L engine
260 mm – vehicles with 1.6L or 1.8L petrol engine
280 mm - LV Focus 2.5L Duratec-ST
302 mm - LV Focus 2.5L Duratec-RS only
Some LS/LT models were equipped with 228 mm drum brakes on the rear.
Old 18-03-2021, 12:02 PM   #10
brucewarring
thanks very much for that Russell...keep up the good work for all of us dumb oldies
Old 30-03-2021, 07:28 PM   #11
Skwirls
Originally Posted by russellw View Post
LS/LT/LV Front[/B]
Well I finally got them checked and they're 278mm on a 2.0 Diesel so something is wrong somewhere. Perhaps the 300mm was an optional upgrade?
