04-06-2019, 02:15 PM | #1 | ||
A technical question for you guru's.
My Series 3 wagon (FlashCab) comes up on Etis as having a M85LE, These were only supposed to be fitted to the Falcon/Fairmont (EA II, EB I): 3.9-litre, where as all AU I6's should be M93LE. Does anyone know what differences there are and if I can successfully swap the column shift to a floor shift using AU parts or if I can swap the current auto for an AU version without dramas with the BEM etc? TIA
Graham South of DARWIN NT AUIII Flash Cab project (nearing completion) |
04-06-2019, 02:18 PM | #2 | ||
See page 3 and page 8 onwards of https://www.tiperformance.com.au/Ref...Speed_Auto.pdf
regards Blue |
05-06-2019, 02:37 AM | #3 | |||
28-02-2021, 10:30 AM | #4 | ||
Revival of old thread and hoping to get a better understanding of the interchangeability of the BTR M91 M93 and NOT transmissions.
Specifically I run a couple of 94 NCii Fairlanes (BTR M91LE I assume), plus a couple of BA wagons for towing (M93LE). I have acquired a couple of spare M93LE transmissions and hope these are also useful as spares for the NC Fairlanes. As per the article attached above on page 3 there are numerous modifications between the M91 and M93. Hoping someone with a better understanding is able to enlighten me as to whether an M93 will be a direct fit to a car previously running an M91? |
28-02-2021, 11:39 AM | #5 | ||
Is the NC a 6 or a V8?
regards Blue |
28-02-2021, 10:02 PM | #6 | ||
28-02-2021, 11:28 PM | #7 | |||
regards Blue |
01-03-2021, 12:17 AM | #9 | ||
