Old 01-02-2021, 04:05 PM   #1
Jen84
Default Leak off pipes
Hi all
I recently had the leak off pipes replaced due to one leaking (which ultimately caused a small fire under the bonnet ).
A certified reputable mechanic did this replacement . Unfortunately the leak off pipes keep popping out , it’s not always the same one .
The clips are new also, also no pressure issues .
Has anyone had this problem and been able to solve it . I can’t really drive it as you never know when one is going to pop out .
2010 mondeo titanium tdci
Jen84 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2021, 09:19 AM   #2
rondeo
Default Re: Leak off pipes
Metal cips or green plastic tabs?
They changed sometime in 2010 I gather.
http://www.catcar.info/ford/?lang=en...ODg4OCsxMzM%3D
shows (9A317) a metal clip.
These potentially get weaker by over extension when installing.
Solution might be to bend them back a bit. They should be installed before the leak off pipe is pressed in.
Another idea is to cable tie them in as emergency backup.
I googled it out of interest, no problems with mine, plastic tabs.
Old 02-02-2021, 09:30 AM   #3
Jen84
They are the metal clips
