hi need to know what i need to do to put a sports dash into a standard ea oil guage, taco, and anything else i should know thanks
Gunna girlie-man
hey mate, follow this link and it will tell you how
http://www.fordmods.com/forums/documents.php?doc=45
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
#3 | |||
![]() Join Date: Dec 2004
I think that's it. With the cluster you should get a oil pressure switch, which is located under the inlet manifold. The tachometer wire is hanging loose at the top left hand side of the engine bay. Run a wire from this through to the back of the cluster and it goes into one of the pins at the bottom. I can't remember exactly which one, because it's probably 4 years ago that I did this.
It's a pretty easy job. Good luck with it. Ash
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
Gunna girlie-man
tachometer wire is pink with blue stripe, and the oil pressure switch is located about 2 inches above the oil filter. if you buy a sports dash, itll set u back around $47 from a wrecker. and if you need an oil pressure switch, it wont come with the purchase of the instrument cluster.
#5 | |||
Is that all they're worth these days? I remember paying about $120 back in the day...
