07-11-2012, 06:38 PM | #61 | ||
Sick Puppy
All good mate. It gets here when it gets here.
Will end up being put on the parts shelf for probably 6 months till I get around to doing all of the bushes anyway.............. |
08-11-2012, 08:40 AM | #62 | ||
RIP...
No problem, I've just dicked a few people around sending out my IRS mounts too.
. Oval Everywhere... |
08-11-2012, 11:57 AM | #64 | ||
RIP...
It's not hard mate, just be forgetful, clumsy, and confused, and you should be eligible.
09-11-2012, 08:06 PM | #65 | ||
I miss my wheelbarrow
Bushes are sent guys, all freight cost was between 13 and 15 buck each because it went past 500grams (now I know why my B-Series bushes are alloy unreal!)
Jeff I have sent two as per out discussion and I have also included a spare stock one for the Mrs car in case. Dave your bush is at Veale Booragoon as discussed. Sox I'll get the bank details to you mate. Thanks again for this guys, much appreciated Daniel |
11-11-2012, 02:32 PM | #66 | ||
Awesome thanks Daniel! I'll be like Mr EL... It's going to sit on the shelf for a while til I do my rear suspension.
12-11-2012, 03:23 PM | #67 | ||
Thanks Daniel - mine arrived this morning. PM me your details please mate. (or do I already have them - I'll have to check)
12-11-2012, 04:10 PM | #68 | ||
Got mine today Dan, thanks again. Quick question because I haven't looked at the car too closely, chamfered side up or down?
13-11-2012, 12:47 AM | #69 | ||
Its on page 1 I think, chamfer up and to the front of the car, rubber under that and the whole lot sits on top of the diff casting with the lower bush and bolt in the factory positions.
Daniel |
13-11-2012, 10:01 AM | #70 | ||
Thanks Dan!
13-11-2012, 04:38 PM | #71 | ||
Tickford
How's your stock levels Dan?
I'm planning a 3.9 diff change soon (and some Wednesday fun) so I might as well kill two birds with one stone.
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD BA XT SZ Territory TS RWD TDCi |
13-11-2012, 09:52 PM | #72 | ||
RIP...
Mine came today, thanks.
Pm your bank details.
14-11-2012, 02:27 AM | #73 | ||
17-02-2013, 09:23 PM | #74 | ||
EDH
hi how do i go about getting one of ur diff bushes for a ba falcon ?
looks faster than it goes |
17-02-2013, 10:37 PM | #75 | ||
Hey mate, my BA-FG control blade bush kits come as a set of 3 and go for $440 incl freight and GST. If you are keen PM me, I'm out of fronts for another couple of weeks while the next batch is being made
Daniel |
24-12-2013, 12:31 PM | #76 | ||
Hi mate, do you have any more of these available for an au series 1 xr8 and if so how much are they? Also please excuse my nievety but is this bush also referred to as the diff mount or is that a seperate item? I recently bought my first v8 falcon and replaced every bush in the car as well as as the suspension but didn't do the diff bushes and rear upper shock mounts. As luck would have it seeing as everything else is now new these parts are particularly knowticably buggered. Having all sorts of trouble finding them!
Cheers |
25-12-2013, 02:51 PM | #77 | ||
No mate I did a group buy run and sold the rest of my stock. The factory parts are ok in most applications and adding a secondary washer to sit behind the bush... This is for the mount at the front of the diff next to where the tail shaft connects to the diff
Daniel |
22-08-2014, 11:46 PM | #78 | ||
hello all out there in ford land. im new to forums so you will have to forgive me.
i have an AU fairlane V8 5.0ltr and im chassing the three diff bushes for it. ford say nil stock and good luck. nolathane dont list them and superpro or mackay dont list them? does anyone know of any lying around somewhere or does someone else make them? cheers shane |
27-08-2014, 04:21 PM | #79 | ||
Chasing diff mount bushes for an AU XR8, does anyone manufacture these as ford say they have not been available for 5 years
Thanks Dave |
20-05-2020, 01:58 PM | #80 | ||
New IRS diff bush mount kit for AU series released by SuerPro early this year, Can get from Supercheap Auto or Bursons, not sure about Repco
https://superpro.com.au/whats-new/16...mount-bush-kit |
