Old 28-07-2019, 08:10 PM   #1
Edxr6
Default AU XR8 series 3
Fellas,
My Antenna on my XR8 wouldn’t re-tract back into the guard today, any ideas and can they be repaired or fixed. By the way it’s not bent, it was working fine, until when I was ready to drive it back into the garage after today’s drive.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2019, 10:54 PM   #2
Ken Wilson
Will
Default Re: AU XR8 series 3
I would try some lubricant, it has worked for me in the past.
Ken Wilson is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2019, 06:15 AM   #3
Edxr6
Thanks Ken, I will give it go today.
Regards
Old 29-07-2019, 06:17 AM   #4
PG2
#neuteredlyfe
PG2's Avatar
You will need to pull it out from behind the guard - it is a reasonably easy job.
If it is not an easy job to repair you may need one of these...
https://www.ebay.com.au/itm/Ford-Fal...frcectupt=true
The one on my ute decided not to work anymore. I bought the rope kit but then came across a perfectly functioning one at the wreckers for a good price.
There are plenty of youtube videos on how to fix them.
Old 29-07-2019, 10:19 AM   #5
Ken Wilson
Will
Regards
No worries, if that doesn't work, I would chase up a second hand unit.
Old 29-07-2019, 10:51 AM   #6
I think on Foster Ute, the antenna had become a structural member by default.
More seriously, I’d allow some time to clean and inspect the area. Above and slightly behind the motor housing is a prime rust area. Compost wedged in the scuttle corrodes outwards into the void, then spreads down the “branch” of bracing on the outside of the firewall-to-jamb closing panel.
So - wheel off, liner out, flyspray the area, dry vacuum, remove antenna, inspect and wash/treat as required. Then as Haynes like to say “Reassembly is the reverse of removal”...
Old 29-07-2019, 11:38 AM   #7
Edxr6
Ken,
It was oiled before I left for work, see how it goes.
Regards
Old 29-07-2019, 11:40 AM   #8
Edxr6
Citroenbender,
If the lubricant doesn’t work, then your operation sounds like the next step.
Regards
Old 29-07-2019, 11:43 AM   #9
Edxr6
PG2,
If the lubricant doesn’t work, then out for inspection and assessing the unit to ascertain the issue.
Old 04-08-2019, 05:17 PM   #10
Edxr6
OK, the lubricant didn’t work, so I took the opportunity today to remove the antenna. Removed the antenna from behind the guard, took the Black plastic cover off the unit and noticed the plastic retractor cable had snapped in half, replace with Arepro antenna, the closet available to original, $32.00 from Repco. All back together working fine.
Thanks fellas for all the help.
Old 08-08-2019, 09:46 PM   #11
Edxr6
Cheers PG2, that’s what I replaced it with, the hardest part of the job was removing the inner splash guard. Now I have to find the three scivits for my side skirt, it was basically impossible to remove them without snapping them off to take the splash guard out.
