09-07-2019, 10:01 PM | #1 | ||
Fellas,
I have some power steering fluid weeping around the top of the pump where the inlet pipe runs through the large nut. Is there an o-ring or two around this area, either around the inlet pipe, nut or both. Also is it just the case of undoing the nut to replace the o-ring? Any assistance would be great full. Cheers |
12-07-2019, 11:30 AM | #2 | ||
Mate there are a number of threads covering this common problem and how to fix it. The search function here is your friend - use it.
Unfortunately its not as simple as you would like and you need to buy a new nut as they have a captured retainer clip and it s a very tedious process to remove the nut off the line or buy a complete line. Ebay will help you for the nut
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
