Old 09-06-2019, 08:28 PM   #1
Tonz
Default Light bars
whats good & Bad, whats the difference between ones from Ebay to Autobarn or similar shops, how can one know the difference?
I am looking at about 600-800mm across
Old 10-06-2019, 01:54 AM   #2
Trevor 57
Trevor 57's Avatar
Default Re: Light bars
look for the amount of lux
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 06:37 AM   #3
buggerlugs
If it ain't broke........
Mum used to use that........
Visitors welcome
Relatives by appointment only
buggerlugs is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 08:08 AM   #4
Tonz
its just their word (sellers) how can that be guaranteed?
Old 10-06-2019, 10:12 AM   #5
EBSXR6
EBSXR6's Avatar
It cannot unless you have a reference for the product, someone you know has the same product or you have seen it in a retail shop.
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 10:59 AM   #6
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
At distance too - nothing beats HID spotlights for the amount of light down range.
Old 10-06-2019, 02:58 PM   #7
prydey
Rob
prydey's Avatar
99% of ebay stuff will be ordinary.
I did a lot of research when I bought my light bar and most of the big name stuff (rigid industries, baja, lightforce etc) are superior in most tests, but you pay substantially more for it.
I bought my latest one from Stedi. They performed well in independent testing and are substantially cheaper.
My reasons for this is the amount of time I will actually need to use it. If I was needing it every day or regularly enough, I probably would have stumped up the extra for a big name brand, but I will use it a handful of times a year, and it will do the job while still being very well built.
The other reason is, you don't need to be seeing 1km down the road. as long as you can see beyond your braking distance + reaction time at the max speed limit, then that is fine. mine has a fairly narrow spot beam (5degree) with 40deg ( I think) flood beam. It suits my needs.
if you need a lot of light, and have the ability to mount spot lights rather than a light bar, I would still stick with spot lights.
UA2 TREND 4WD BI TURBO
prydey is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 03:16 PM   #8
Beam angle is also something important to consider. You can have all the light output you like, but if the beam isnt where you want it to be then its no good. A narrow beam tends to project further but not pick up periferal, a wide beam wont project as far but will pick up more periferal. Just another thing to consider.
Old 10-06-2019, 03:50 PM   #9
Franco Cozzo
Thailand Specials
LED bars are awesome for a real wide flood up to 150M or so, they're not real good at useful light at further distances but at the end of the day I find I'd rather see wider up to 150M in front of me than 500M+ down the road.
Come across this bloody furry gypsy and 5 of his mates on my way home from Heathcote on Friday night after the test and tune.
In this situation more lights are useless as it's just curvy windy roads where it's road then trees and that's probably the most likely encounter you'll have with the furry gypsies.
For one of these vegan flogs he's pretty muscly 💪
Shares the same diet as women with bright blue hair and tattoos in Melbourne's inner suburbs
7 users like this post:
Old 10-06-2019, 05:25 PM   #10
Blue Dog
Not too sure about that, for example here's a hand held torch..............
The LedLenser X21R, the figures alone are impressive:
5,000 lumens light output with a beam range of up to 800 metres & maximum run time of 40 hours.
The unbelievable beam range of this flashlight will completely amaze its user - its light beam can cross the length of eight soccer fields, which makes it the perfect searchlight!
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 07:26 PM   #11
03 GHIA
Have had a few light bars, but none of any big name brand.
From the ones I've had, bars with fewer higher wattage LED chips beat those than have many lower wattage chips.
To get a more accurate wattage, it's best to go off current draw rather than specified wattage.
Current
Viper 2010 50th Anniversary XR6T
Stock, but for how long...
Previous
White 2003 Fairmont Ghia
First- RIP.
White 1990 Ford Fairmont
Exhaust, intake, cam & lowered.
03 GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 07:29 PM   #12
hayseed
I've got a couple of Slimline ones (20" & a 30") from 4WD supercentre. they seem fine...
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2019, 07:41 PM   #13
Franco Cozzo
Thailand Specials
How many lumens are there at 800m though? That's where the secret lies.
Sure it has 5000 lumens at the reflector but the real test is at the 800M mark and that's where the difference lies between LED and HID.
The latter as a general rule has more light at the opposite end of the beam.
Old 10-06-2019, 07:53 PM   #14
prydey
Rob
prydey's Avatar
The old saying 'you get what you pay for' is pretty accurate for most things in life, and in this case, esp driving lights.
Also, poor man pays twice, or
Buy nice or buy twice
Old 10-06-2019, 07:53 PM   #15
yakcam
I drank what?
yakcam's Avatar
Same razor too by the looks of it
I will not be taking any criticism, constructive or otherwise.
yakcam is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2019, 01:16 PM   #16
Itsme
Experienced Member
Itsme's Avatar
Stay away from the cheap Ebay ones if you want decent performance, I would suggest you visit the 4WD stores for advise but be prepared to pay big $$$$.
I've seen some led bars and lights that are just as good or even better than HID's.
Old 11-06-2019, 04:10 PM   #17
GTLEGEND
Lumen do a good bar that's plug and play with a Ranger/Everest and sold as a Ford accessory..click on link below and scroll down the page if it does not come up automatically.
https://www.ford.com.au/commercial/ranger/accessories/double-cab-pick-up/4x4-xlt-double-cab-pick-up-3-2l/#overlay/content/ford/au/en_au/ranger-content-2019/image-overlays/ranger-accessory/ranger-accessory-overlays.html?wcmmode=disabled&param=%257B%2522ima ge%2522%253A%2522%252Fcontent%252Fdam%252FFord%252 Fwebsite-assets%252Fap%252Fau%252Fbuildprice%252Faccessory% 252Fexterior%252FVGB3Z13B218A.jpg%2522%252C%2522fe atureName%2522%253A%2522LED%2520Light%2520Bar%2520-%2520Lumen%2522%252C%2522featureDescription%2522%2 53A%2522%253Cul%253E%253Cli%253ECompliment%2520you r%2520Everest%25E2%2580%2599s%2520Nudge%2520or%252 0Bull%2520bar%2520with%2520the%2520Lumen%2520perfo rmance%252020.5%25E2%2580%259D%2520slimline%2520LE D%2520light%2520bar%2520that%2520provides%2520supe rior%2520illumination%2520when%2520driving%2520at% 2520night.%255Cn%253Cli%253EThe%2520Lumen%2520ligh t%2520bar%2520provides%2520a%2520combination%2520b eam%2520that%2520is%2520great%2520for%2520wide%252 0angle%2520short%2520range%2520illumination%252C%2 520but%2520maintains%2520its%2520performance%2520o ver%2520long%2520distances.%253C%252Fli%253E%255Cn %253Cli%253EHave%2520the%2520peace%2520of%2520mind %2520knowing%2520that%2520the%2520light%2520bar%25 20has%2520passed%2520extensive%2520product%2520tes ting.%253C%252Fli%253E%255Cn%253Cli%253ESpecificat ions%253D%2520LED%2520power%2520(15x3W)%252C%2520L ux%252F10m%25201885%252C%2520Waterproof%2520rating %2520IP67%252C%2520Colour%2520temperature%25206000 k%252C%2520Dimensions%252020.5%255C%2522%252C%2520 LED%2520life%2520span%252050%252C000%2520hours%252 C%2520Dimensions%2520524x59x52mm%253C%252Fli%253E% 253C%252Ful%253E%255Cn%253Cp%253EThis%2520accessor y%2520%2520is%2520a%2520Supplier%2520Branded%2520A ccessory%2520and%2520is%2520not%2520manufactured%2 520or%2520warranted%2520by%2520Ford.%2520The%2520w arranty%2520is%2520provided%2520by%2520the%2520man ufacturer%2520of%2520the%2520accessory.%2520The%25 20information%2520in%2520this%2520document%2520rel ating%2520to%2520this%2520accessory%2520%2520is%25 20based%2520on%2520information%2520provided%2520by %2520the%2520manufacturer%2520of%2520the%2520acces sory.%253C%252Fp%253E%2522%252C%2522disclaimer%252 2%253A%2522%25253Cp%25253E*Fitted%252520RRP%252520 (including%252520GST)%252520for%252520Dealer%25252 0fitted%252520accessory%252520at%252520%25253Cu%25 253Eparticipating%252520Dealers%25253C%252Fu%25253 E.%252520Based%252520on%252520RRP%252520for%252520 accessory%252C%252520standard%252520labour%252520t ime%252520%2526%252520recommended%252520hourly%252 520labour%252520rate.%252520%25253C%252Fp%25253E%2 522%252C%2522partNumber%2522%253A%2522VGB3Z13B218A %2522%252C%2522cost%2522%253A%2522%2524637%2522%25 2C%2522partNumberTitle%2522%253A%2522Part%2520Numb er%2522%252C%2522partPricePrefix%2522%253A%2522%25 22%252C%2522costTitle%2522%253A%2522Price%2522%252 C%2522isHideFeatureDescription%2522%253Afalse%252C %2522isHideDisclaimer%2522%253Afalse%252C%2522isHi dePartNumber%2522%253Afalse%252C%2522accPartPriceS uffix%2522%253A%2522*%2522%257D
Old 11-06-2019, 05:39 PM   #18
FoxtrotGolfXray 5.0
FoxtrotGolfXray 5.0's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willingly providing technical info and documents, despite glitches.
There goes the server bandwidth of aff with that url
Labels are for jars, not for people.
Life is a journey, not a destination.
Daily: 2013 FGII EcoLPi in Winter White
Play: 2015 FG X XR8 in Emperor Show' N Shine thread
Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor
FoxtrotGolfXray 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2019, 08:55 PM   #19
GTLEGEND
Did not realise it was that long until I posted...straight from the Ford website?
Old 11-06-2019, 09:24 PM   #20
naddis01
naddis01's Avatar
Not a light bar but still LED.
https://www.4wdsupacentre.com.au/kin...tres-ip68.html
Supposedly 1 lux at 1200m. $229.
naddis01 is online now   Reply With Quote Multi-Quote with this Post
Old 11-06-2019, 09:29 PM   #21
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
I suppose you would need to use a lighting accessory you a happy with.
I have Lightforce spotties on ma Ute, been there forever, they are a focusable light and I flare them for local work (mostly wallabies/Deer) and on longer trips I focus them down the road to give me long range performance. Been very happy with them for years.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2019, 02:17 AM   #22
prydey
Rob
prydey's Avatar
Another thing to look for is colour temperature. Anything decent will be around 5000k give or take a few hundred. Most of the cheap junk will be 6000k or higher. This is too far toward the blue end of the spectrum to be effective. Don't mistake brighter light as being better. It's way too reflective. Road side signs will blind you. Too white/blue will also be a lot less effective in rain. Yellower light will actually penetrate a lot better which is aghast you need.
As well as colour, there is also the beam pattern to take in to account. Anything that hasn't been photometrically tested I wouldn't waste my time with.
Old 13-06-2019, 07:20 AM   #23
5.8
5.8's Avatar
I just bought a pair of these in 7” as that’s all I could fit on my bullbar. $79 for the lights and $40 for the plug in fitting kit. Brilliant light, I couldn’t imagine why you would need more light out there. Hopefully they have longevity given the price. We’ll see.
5.8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2019, 04:04 PM   #24
Tonz
with an FG the round lights look so strange and out of place, yes I would prefer them but for ascetically pleasing appeal light bars are the go.
I have one at present but thinking it could be better but also toying with mounting it on roof of the ute canopy as a reversing light
Old 13-06-2019, 09:32 PM   #25
FoxtrotGolfXray 5.0
Also wanted to just let people know to be wary of claims of lux levels (lumens) with some of the lesser known brands. I'm no expert on the subject matter, but I looked after a project at our work where we replaced traditional fluorescent light fittings with industrial LED fittings. The company I dealt with did all of their design work in Melbourne and their lights were extremely robust and were very efficient (and cost a bomb).
One of the designers was talking to me about the measurement of lux levels. He advised me that there are two ways of measuring the light output; one directly at the Printed Circuit Board (PCB) and the other off the board. In this case, IIRC, the same lux level measured off the board produces, generally, a higher output light. It is a way for a poorer performing light to be expressed in better terms.
Do a search, and there are numerous sites that talk about the difference between lux and lumens, and the (non)association with wattage. This one for example.
Hope that helps.
Old 16-06-2019, 11:20 AM   #26
MattSAU2XR8
Probably worth looking at Gemtek as well
I just bought one of these - a 12 inch double row light bar with offset reflectors as per the Narva light bars. Only cost $129 with wiring kit. Still to fit it though.
Offset reflectors seem to be a good thing since if the LED is facing up or down rather than forward, and the reflector is at about 45 degrees, halfway between vertical and horizontal, most of the emitted light will actually hit the reflector and can be directed forward, rather then just spilling out as a flood beam. Food for thought...
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
