Old 20-04-2019, 09:58 PM   #1
Edxr6
Default AU Odometer Globes
Guys
One of my odometer globes wasn’t working, replaced the globe, now both aren’t working after the wiring looms had been plugged into the cluster. Any suggestions, it’s got me beat.
Regards
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2019, 10:36 PM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: AU Odometer Globes
Originally Posted by Edxr6 View Post
Guys
Regards
What sort of globe did you replace the original globe with?
They can be very temperamental, make sure they are in nice and tight. Even shove some alfoil in between the globe connector and circuit board where you plug them in.
Old 21-04-2019, 07:24 AM   #3
Edxr6
PG2
I used the original and the one that was working I didn’t touch.
Old 21-04-2019, 07:25 PM   #4
I had an issue a bit like this with the clock light. The contacts were not making good on the tracks of the circuit board.
As it was a phenolic board the easiest repair was to build up the tracks with a thin layer of solder. The other approach is to build up the contact pads on the globe assembly. You need to be reasonably handy at soldering, have a fairly hot iron and cleaned substrate.
Old 22-04-2019, 03:08 PM   #5
Edxr6
PG2,
Tried the Alfoil, still no good. What hassle, the worst part is the plugging and unplugging of the cluster, so tight. I will buy two new Globes, just in case it’s the Globes. Then start again, if still no good I will revert to the soldering iron.
Old 05-05-2019, 01:37 PM   #6
Edxr6
Fellas,
Brought two new globes, still not working?
Regards
Old 05-05-2019, 01:50 PM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Dont have a spare cluster around to check?
Uk
Just a thought
Old 05-05-2019, 06:25 PM   #8
Have you got voltage?
Old 05-05-2019, 07:25 PM   #9
Edxr6
Citroenbender,
I assume yes, because all other lights are working on the instrument cluster.
Old 05-05-2019, 07:26 PM   #10
Edxr6
Uk
Just a thought
Old 07-05-2019, 10:35 PM   #11
I'm going to suggest you start with a simple test using something like a 1.2W T-5 wedge globe. Power up the cluster lighting, and "unpick" the wire tails of the T-5, touch one wire leg to each contact pad for a dash illumination globe and see if it lights up.
Silly question, but you have tried both positions (dimmer and brighter) of the dash illumination control?
Old 08-05-2019, 08:22 PM   #12
thexd351
Hi
I had this happen, I used LEDs and that fixed the issue for me at least. The down side is that they're illuminated all the time when the key is on.
If this will work for you as it did for me I can't say. Purely an option to think about.
thexd351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2019, 02:31 PM   #13
Edxr6
Citroenbender,
The dimmer is all good, I will try the test with a couple globes I got from the wreckers as soon as I get some time. It’s really frustrating and a problematic issue. It must be a common problem once the factory globes blow?
Old 16-05-2019, 10:13 AM   #14
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Just get a pair of these and fit them.
They don't light up as uniformly as factory globes but close.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2019, 12:24 PM   #15
Edxr6
PridenJoy,
I brought two new globes from Burson’s and still won’t light up?
Regards
Old 16-05-2019, 01:05 PM   #16
PridenJoy
Then, other than swapping over the globes which has worked for me in the past, cluster itself is the issue.
