Old 02-05-2019, 04:13 PM   #1
timmb
Default AU Fairmont fuel lune snapped
My fuel line broke while replacing the fuel filter on my AU Fairmont wagon. It snapped off about 3 inches from the fuel filter. Has anybody had any experience with this in terms of replacement cost. Or is it possible to repair it in anyway.
timmb is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2019, 05:45 PM   #2
Default Re: AU Fairmont fuel lune snapped
Is it a inline 6 or V8? If it's a 6 you can probably just cut the two broken ends square with a tubing cutter, flare (double laps or bubble flare) those ends and insert a piece of high pressure fuel hose (this stuff https://www.supercheapauto.com.au/p-...ose&lang=en_AU ) on the newly cut and flared ends fastened with high quality hose clamps. Cutter and flarer in a kit: https://www.supercheapauto.com.au/p/...ool&lang=en_AU
Old 02-05-2019, 05:52 PM   #3
Itsme
Experienced Member
Itsme's Avatar
You should have no problems sourcing another one from the wreckers for minimal cost.
Old 02-05-2019, 05:56 PM   #4
Is it tank or engine side that broke?
Old 02-05-2019, 07:32 PM   #5
snap0964
And why did it snap? Rough treatment or corrosion ?
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2019, 10:44 PM   #6
timmb
It snapped engine side of the filter
Old 02-05-2019, 10:45 PM   #7
That's good; it's the shortest length so a new or used line will be easier to put in.
