Old 27-03-2006, 05:30 PM   #1
syktlr
stktlr
syktlr's Avatar
Default help:el into ea?
can get a el motor with 110thou on it for 650.apart from changing the ecu to a ea mpfi one as mine is cfi and using a mpfi fuel pump what else is to be done? it comes with everything and i guess i have to use the engine loom of it or do i have to get an ea mpfi one.will my power steer and a/c along with the balancer fit onto it or do i use the el ones? it doesnt come with the steer and ac pump so if i could use mine it would be great.do i just plug it in and then it works?im under the impression that i have to get a 3spd kickdown cable of a mpfi ea and the throttle body of one to. can the el throttle body be used at all? if i use my pulleys will it be okay to run the fan?thanks
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2006, 05:45 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
get the el motor, keep the serpentine, put in a set of thermos, and you can bolt all the normal EA intake\exhaust on and enjoy.
I have an EF motor in my car, but i also converted to 4 speed auto.
Old 27-03-2006, 05:50 PM   #3
syktlr
stktlr
syktlr's Avatar
so the intake from el wont work? mines cfi does that make a diff
Old 27-03-2006, 05:59 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
with a 3speed auto, it cant work, unless you dont want a kickdown cable , you plan on a real trick set up.
otherwise yes the el manifold can be used, search on 'BBM*' in the e-series forum if you want details on fitting one.
Old 27-03-2006, 06:00 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
CFI or MPFI no big deal, bolt all the CFI stuff back on to get the car going first, convert to MPFI later if you want.
Old 27-03-2006, 06:19 PM   #6
syktlr
stktlr
syktlr's Avatar
ive been told about putting a ea mpfi throttle body on it and using the matching kickdown cable that it would work. is this true?then when i get more cash and get a 4spd put it back to el and all is good/
