Old 15-05-2018, 09:06 PM   #1
Sumo
Default Glow plugs on mondeo 2011 mk4.5 tdci 2.0
Hiya all, been searching around all over but can't find where the glow plugs is location on my 2011 mondeo tdci 2.0 mk4.5. Anyone have link or picture can show me where? So I can change them.
Been a couple months now that engine malfunction light come on after driving for abit, no loss of power, but fuel efficiency definitly have decrease. Two times I've taken it to two difference mechanic, and both time sayglow plugs fail. Car start fine every time but have high fuel consumption first couple minutes, then goes back to relatively normal. Unsure if it's the dpf or glow plugs. But thinking changing the glow plugs first since it's cheapest I persime.
Thanks
Sumo is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2018, 06:10 AM   #2
russellw
russellw's Avatar
Default Re: Glow plugs on mondeo 2011 mk4.5 tdci 2.0
See below for location.
The original glow plugs are Bosch P/N 00 250 202 048 but they will set you back $45 each (there are 4 of course). Tridon TGP009 should be a direct replacement for around $26 each.
Russ
Old 16-05-2018, 12:38 PM   #3
Sumo
Thanks for reply.
Should I look for that on top or bottom of the engine?
Old 19-05-2018, 05:33 PM   #4
Sumo
Where can I find the glow plugs on this mondeo? Search everywhere on the net, look though my car, open the injector and shielding underneath the car. I can't find what resemble the diagram.
Able to find for mk4, but for the 2.0 mk4.5 MC. Just can't find anywhere.
Old 21-05-2018, 12:32 AM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
They're on the cylinder head below the plastic intake manifold down low as it shows in the diagram RusellW posted no doubt behind all the other crap in it's way.
See below:
Geez ya lucky my google fu is strong this week ;)
Undecided replacement...
Old 21-05-2018, 09:14 AM   #6
rondeo
Exciting video:
https://www.youtube.com/watch?v=W9lzWWGj8LM
Old 27-05-2018, 11:05 AM   #7
bundybear75
bundybear75's Avatar
See below:
No wonder I couldn't find them when I did my timing belt change. I wanted to pull them out to make the crank easier to turn by hand. I thought they would be on top near the injectors but I couldn't find them.....
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2018, 11:51 AM   #8
rondeo
How easy did the crank turn by hand?
Old 27-05-2018, 12:37 PM   #9
bundybear75
It did take some turning. I used a long breaker bar. You could feel the compression build up and then release. Would of been much easier if I had removed the glow plugs.....
2002 BMW R1150GS
Old 27-05-2018, 09:46 PM   #10
cobrin
Challenge Accepted!
cobrin's Avatar
I guess it's up to the individual lol, I thought it were very easy to turn over by hand, but full disclosure, I've turned over 35L and smaller V16/8 and 6cyl MTU/CAT/Komatsu/Detroit/Perkins/DJ, engines so whilst they too are easy with purpose built turning tools, I felt the lil Duratorq 2.0L gave light resistance on the crank with a 600mm breaker bar.
Old 09-08-2018, 08:24 AM   #11
Sumo
So is there any video, guide on how to remove the plastic intake manifold? Anything I need to watch out for before I start removing the manifold? Does the car need to be jack for the mk 4.5?
Old 09-08-2018, 06:07 PM   #12
rondeo
Haynes manual is quite good but does not cover Getrag DCT.
https://www.worldofbooks.com/en-au/b...SABEgKgjPD_BwE
From that manual I read three bolts hold the upper and lower manifold together, and three nuts hold the lower manifold to the cylinder head.
