Old 30-04-2018, 03:16 PM   #1
TonyHuynh
Default Ford Fairmont BA MKII 2004: ICC problems
Hi
My ICC has been playing up for a while, it stopped and worked again by itself at any time when the car was running. It remembered the status the last time it was on, ex. aircond on or off, the fan speed level. When it stopped the only thing I could operate was the Radio button on the steering wheel.
3 days ago it is dead completely but the fan still works as it was the last time the ICC was working.
Now on the instrument panel, all the warning lights of fuel, oil, temperature, brake show up. The engine's RPM, speed indicator, coolant temperature indicator are no longer work except Fuel level indicator.
My questions:
1/ I don't know whether is it safe to drive ? I need to drive to the repairer.
2/ Is the ICC caused the problem and it relates to the instrument panel warning indicators ?
Thanks for your advise.
TonyHuynh is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2018, 05:37 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Ford Fairmont BA MKII 2004: ICC problems
Yes and probably yes.
Observatio Facta Rotae
Old 01-05-2018, 12:41 PM   #3
BAWITHLOT
XB COUPE TOO!
BAWITHLOT's Avatar
It almost sounds like your battery is buggered. Do you drive the car everyday and how old is the battery?
BAWITHLOT is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2018, 01:43 PM   #4
11ford11
Try removing icc reset plug at rear by pulling towards you and refitting icc. It may be interrupting the bus wires
Old 01-05-2018, 08:40 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Have a look at this post https://fordforums.com.au/showthread...&highlight=icc . It is about a faulty speaker problem but was a fault with the ICC. A fault in the same location can lead to many different problems. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 02-05-2018, 11:53 PM   #6
TonyHuynh
It could be this. Earlier the right front speaker was on or off, the same with the ICC display. When the ICC stopped, I knocked it hard on the side and sometimes it worked back.
Old 02-05-2018, 11:55 PM   #7
TonyHuynh
I have tried to remove the plugs but it was too difficult, will try again.
Old 02-05-2018, 11:58 PM   #8
TonyHuynh
I don't use the car often, may be once in a few days. The battery is about 2,3 years. Have checked the voltage and fuses, they are all seem ok.
Thanks
Old 06-05-2018, 06:19 PM   #9
TonyHuynh
I tried to remove the ICC to inspect the inside but could not remove the 4 plugs at the back, could only undone 2 plugs.
So I used the torch to inspect the wiring that connect to ICC, they seem all ok.
However, when I opened the cover of the steering wheel, I found 1 wire with black and pink color is cut off from the plug. The plug is next to the ignition switch. I marked it with red pointer in the picture. Please see picture attached.
https://drive.google.com/file/d/1BeE...ew?usp=sharing
This wire is a bit shorter than the rest. I don't know whether it was intentionally cut off or else. I could not remove this plug to see it properly.
Any guess ?
Thanks
Old 06-05-2018, 09:32 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. the 4 plugs under the ICC unit are the connections for the BCM (body control module) that is screwed to the base of the ICC. The wiring for the ICC unit is one self aligning, auto latching plug on the back of the ICC. It is the ICC side of this plug that you need to check for the faulty solder joints between the pins on the plug and the circuit board in the ICC. Cheers MD
HI
I'M MICHAEL
