11-10-2017, 03:50 PM | #1 | ||
Giddy up.
How do you remove the anti-theft screws that hold a number plate and re-use them, the reason being is that I have them on my vehicle but just purchased some number plate protectors today and I need to use the existing holes if possible.
I can always drill them out or make a notch to get them out and just buy some more latter on, but if there is a way of removing them and being able to re-use them, that would be my preferred option. thanks. |
11-10-2017, 03:58 PM | #2 | ||
Lurking......
Don't reckon you could reuse them. You'd be best of buying a new set and you'll probably have to destroy the set on there to get them off.
11-10-2017, 04:04 PM | #3 | ||
Japanese engineers pliers. http://www.ebay.com.au/itm/ENGINEER-...sAAOSwu-BWPCKJ or http://www.ebay.com.au/itm/Engineer-...AOSwVfxZ0G6Mor http://www.ebay.com.au/itm/mini-plie...sAAOSwj9dZwu3u etc
regards Blue |
11-10-2017, 04:08 PM | #4 | ||
Maybe go to your local police station as they have been known to have days where they fit them for free
11-10-2017, 05:18 PM | #5 | |||
Giddy up.
11-10-2017, 05:19 PM | #6 | ||
Giddy up.
11-10-2017, 05:24 PM | #7 | ||
As you said, just use a grinder with thin cutting disc to cut a groove then remove like any other screw. Just buy new antitheft screws.
11-10-2017, 06:08 PM | #8 | ||
Not sure about other states but in VIC you should be able to go to any Police Station or Vic Roads Office and they should be able to remove them for you as they're meant to have the tools available, or at least that's what I was told when I got mine...
Current Rides: HIS - 2018 PDe Hyundai i30 N 6M - Performance Blue HERS - 2020 MR Mitsubishi Triton GLX-R 6M - Red Past Rides: 1997 EL Ford Fairmont 4A - Navy Blue 2006 BK Mazda 3 SP23 5A - Carbon Grey 2010 LV Ford Focus XR5 Turbo 6M - Frozen White 2013 LW Ford Focus ST 6M - Panther Black |
11-10-2017, 08:03 PM | #9 | |||
I don't have the optional jaw covers that make them look T-Rex like though. Nonetheless a quality tool and up there with my favourite screwdrivers; the Japanses Sunflag Brand More detaisl of teh pliers here: http://www.engineer.jp/en/products/products_e.html ones.
regards Blue Last edited by aussiblue; 11-10-2017 at 08:16 PM. |
11-10-2017, 08:14 PM | #10 | ||
Whats the head of the screws look like? Security bit sets are readily available from most hardware stores. I got the kinchrome set I use for work for $20 from kmart of all places years ago. Depends on the screw head if they're designed only to be screwed in not out, but worst case I use vice grips to get a solid locked grip on the head and spin them out.
11-10-2017, 08:23 PM | #11 | |||
regards Blue |
11-10-2017, 08:49 PM | #12 | |||
11-10-2017, 08:50 PM | #13 | ||
I assume the Superchap tool is like this https://www.youtube.com/watch?v=JZKEmGWzgtQ or https://www.amazon.com/Prime-Line-65.../dp/B00DUQ9LEM
regards Blue Last edited by aussiblue; 11-10-2017 at 09:03 PM. |
11-10-2017, 08:57 PM | #14 | |||
Giddy up.
I rang Autobarn and they were unable to help but I haven't tried Supercheap yet so I will give them a go, thanks mate. |
11-10-2017, 08:58 PM | #15 | |||
11-10-2017, 09:00 PM | #16 | |||
Giddy up.
11-10-2017, 09:02 PM | #17 | ||
Now Fordless
Just use a set of regular pliers
edit - just missed that you said you tried vice grips. Bunnings and co usually sell security bit sets Last edited by Windsor220; 11-10-2017 at 09:07 PM. |
11-10-2017, 09:05 PM | #18 | ||
Yeah that's what the young fella across the road from me did, took him a while but he got there
11-10-2017, 09:09 PM | #19 | |||
regards Blue Last edited by aussiblue; 11-10-2017 at 09:21 PM. |
11-10-2017, 09:12 PM | #20 | ||
Fair call. My plates are short 5 character plates so they are mounted by the inner holes. I've had extremely limited success with those screws (I've spent a lot of time doing demolitions ) bashing a screw driver to create a slot into the slope that stops reversal. The easy way is drill them out but you want to retain them so munting them up and risking the plates or the cars paint isn't an option at all.
11-10-2017, 10:35 PM | #21 | ||
3..2..1..
I just use a big flat plate screw driver, plenty of pressure and unscrew them.
They're about as theft proof as leaving your keys in the ignition and your car parked in the street over night.... |
11-10-2017, 10:46 PM | #22 | ||
Have you tried your local Paint and Panel Shop? They would be removing those screws all the time.
11-10-2017, 10:56 PM | #23 | ||
Hi. If the screw is made to be removed (not all of them are) there will be a small flat on the outer edge of the head of the screw. The tool that fits the screw get enough grip on this flat to remove the screw in most cases as the screw is only done up with a blade screwdriver. To find someone with the tool you need to find out who is doing the "free" fittings of these screws in your area, it may be a rotary club, a lions club or the SES. They should have a contact for someone with the tool, it could be a repco, a supercheap or an autobarn and it may be in the next suburb. and you will need the contact name for the holder of the tool, it wont be sitting in a box beside the till where everyone can get to it. If the screw doesn't have the small flat on it try using some 6 inch side cutters to get a grip on the edge of the screw as the cheap screws are a bit softer than the ones that use the tool. Cheers MD
11-10-2017, 11:27 PM | #24 | ||
Giddy up.
I put some elbow grease into them with the vice grips and got them out, so yeah if your fair dinkum they aren't really that much of an anti-theft, I suppose they would slow a would be thief down but still removable.
Anyway I have completed what I needed to do, thanks for everyones opinions and help. |
12-10-2017, 01:36 PM | #25 | ||
Mopar! But Own F6's..
I dont use them because I clean behind the plates every now and then!
F6 TYPHOON FPV 335 GT |
12-10-2017, 02:16 PM | #26 | ||
If you have access to a dremel use that with a small thin blade. Make a small notch then use a regular flat head screwdriver to get the screw out. I did it with my front number place when I needed to remove it and it worked a treat.
14-10-2017, 08:22 AM | #27 | |||
I threw the stupid effing screws away and used regular ones.
