Old 09-03-2017, 06:11 PM   #1
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Au-bf 6 piston front kits
Hey guys we are looking at some Australian designed and made brake kits for the AU11 to BF models which would be more designed for high performance and or race use.
The calipers are 6 piston and will have internal dust seals and square fluid seals (like AP and Brembo) (no dust boots) and the pad shape is a AP Racing shape so they are available. The front rotor will be a 2 piece set up.
Front Brake kits will sell for around $2995.00 but pad choice will determine final costs as we will not have any particular pad in the kit.
Kit dimensions
2 piece 365mm x 36mm thick , 48 curved vanes , 24 slots on rotor face
6 piston caliper
Billet aluminium caliper bracket
Braided Brake lines
Pads to be determine
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 04-04-2017, 09:20 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Au-bf 6 piston front kits
These kits will sit inwards a bit further than the factory Brembo kits so will fit more wheels.
MATTHEW PEARCE
Phone 02 9609 1101
Old 04-04-2017, 11:34 AM   #3
Nu66et
What rear brake would you pair this with at a minimum?
Nu66et is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2017, 01:18 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
As a minimum the PBR rear 328mm kit but would prefer a 4 piston rear which is being done in the same brand or we have Brembo 4 pot rear kits on super special for $1795 complete at the moment.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-04-2017, 07:37 AM   #5
Nu66et
Is the rotor custom made or an existing item? Justthinking about replacements for the future.
Old 06-04-2017, 08:46 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
It is a custom rotor that is used on other vehicles as well and there are other brands that would replace this rotor. We can also make them fit the factory Brembo 355 x 32mm disc if that is what you are considering.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-04-2017, 09:28 AM   #7
Nu66et
I wouldn't be concerned about the Brembo size rotor, if the disc is common with other vehicles that's good enough for me.
Old 06-04-2017, 12:24 PM   #8
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Sorry just so we are clear the actually rotor used is also used on other brake kits from this supplier so it is common for them.The actual disc rotor itself is not available anywhere else but similar brand rotors with the same bolt pcd are.
The company has been running for a few years now.
MATTHEW PEARCE
Phone 02 9609 1101
