Chairman & Administrator
You'll probably find that the gearbox it contain water too and given that is what the clutch is suspended in then the clutch plate is probably not too good. You can also check the return piston (I believe they were a hydraulic clutch) or cable if they were cable.
Cheers Russ
Observatio Facta Rotae
