Old 02-02-2017, 07:56 PM   #1
mutanti
Turbo
mutanti's Avatar
Default Error P269F Focus Titanium Diesel 2.0
Got an issue with error Code on my Focus Titanium 2 L turbo, Have plugged in my Bluetooth OBD2 connector .
Shows P269F - Exhaust Aftertreatment Glow Plug Cirsuit/ Open
Have reset the Codes and its back again so Where do I start.
Has anyone had same issue.
Not to keen on the Local Ford Dealer due to him been a jerk etc..
Is there a Way I can Check the DPF Glow Plug to see if its working ok ?
I have Multimeters etc just unsure what Values to look for.
Car has been on a few 20 Minute drives so I'm guessing the DPF is not getting a clean out,
Car only has 28000KMS on it.
[IMG][/IMG]
[IMG][/IMG]
mutanti is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2017, 08:03 PM   #2
Trump
bitch lasagne
Trump's Avatar
Default Re: Error P269F Focus Titanium Diesel 2.0
It sounds like a dead glow plug or clagging DPF filter. Does it drive like a slug?
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2017, 08:05 PM   #3
mutanti
Turbo
mutanti's Avatar
It drives as Normal.. No problem at all.
Still has the same kick in the turbo when you give her a tickle so Nothing apart from the annoying message on the Dash..
Old 02-02-2017, 08:14 PM   #4
Trump
bitch lasagne
Trump's Avatar
Might be a sign of a pending failure. If it's under warranty still, could you take it to another dealer?
Old 02-02-2017, 08:15 PM   #5
mutanti
Turbo
mutanti's Avatar
2012 Model so its just out..
Old 02-02-2017, 08:18 PM   #6
Trump
bitch lasagne
Trump's Avatar
Are you able to locate the connector for it, disconnect it and clean the contacts in the socket and plug?
Old 02-02-2017, 08:25 PM   #7
mutanti
Turbo
mutanti's Avatar
Will Do... I believe its at the front of the motor under the Cover that lifts of if I am not mistaken.
Will check it out tomorrow arvo or over the weekend.
Old 02-02-2017, 08:26 PM   #8
Trump
bitch lasagne
Trump's Avatar
Old 02-02-2017, 08:42 PM   #9
DZFord
DZFord's Avatar
There is a TSB for this: http://forscan.org/forum/viewtopic.php?f=6&p=12563
Old 02-02-2017, 08:45 PM   #10
DZFord
DZFord's Avatar
Check the associated fuse, relay and the resistance of the circuit (as per the instructions in the TSB) before throwing any parts at it
Old 04-02-2017, 08:22 PM   #11
mutanti
Turbo
mutanti's Avatar
Ive checked every fuse on the Fuse box under bonnet. - ALL Good
There is a F48 from memory which Doesnt show in the Bible that came with the car bot its the Glow Plug for the DPF i'm Sure. - According to the Car manual..
Unsure if any relays..... cant find much in the Owners Biblle.
Had a lookie under the bonnet and wonder how the hell they work on these cars..
Used to be able to climb into an engine bay once..
Unsure if the Exhaust is under all this palstic on the front or its at the back...
If I cant find the exhaust I'm guessing the DPF will be feeding into it.
And the Glow plug will be screwed into it.
Unser where to start.
Cant even find the bloody thing.
Checked the plugs at front of motor - unplugged and plugged back in..
[IMG][/IMG]
Old 04-02-2017, 08:29 PM   #12
mutanti
Turbo
mutanti's Avatar
Found a Article online.
guessing its under the Floor near Auto Selector...
http://www.fordpers.be/content/asset...AP_TDCi_NL.PDF
Old 04-02-2017, 08:37 PM   #13
mutanti
Turbo
mutanti's Avatar
http://www.autopressnews.com/2005/m0.../engines.shtml
Old 04-02-2017, 09:00 PM   #14
mutanti
Turbo
mutanti's Avatar
So From what I can Find the GLOW PLUG and DPF must be at the back of the Motor. Sounds like htis is going to be FUN.. Not..
Old 04-02-2017, 09:09 PM   #15
DZFord
DZFord's Avatar
Yes, you are correct, F48 is the fuel vapouriser fuse.
See page 144 of the LW Focus manual: http://www.fordservicecontent.com/Fo...2_Aug_2012.pdf
Next step is to get under the car, unplug the vaporiser and test the resistance. You are looking for something like this (note this is from a Mondeo): http://www.ebay.com.au/itm/FORD-MOND...EAAOSwNRdYAHFL
If you have Forscan and the correct OBD connector, you can try to perform a DPF Stationary Regeneration
Old 07-02-2017, 11:42 AM   #16
DZFord
DZFord's Avatar
Worth noting that another member in the Mondeo section is having the same issue: http://www.fordforums.com.au/showthread.php?t=11460529
Old 07-02-2017, 05:10 PM   #17
mutanti
Turbo
mutanti's Avatar
Got it up with my Car ramps and slid under, Its in a Very hard to get to spot.
just my luck.
Going to be Extreemly awkward laying down - Might be a hoist job but managed to get the below.....
[IMG][/IMG]
And Reading from My meter - Disconnected The Plug and somehow managed to Get the probes on the 2 Pins ( And take a photo ).. Hopefully I have done it correctly.....
[IMG][/IMG]
Old 07-02-2017, 11:50 PM   #18
DZFord
DZFord's Avatar
Good job. Looks like a tight fit under there.
That reading is way out of spec. Looks like a new vaporiser is needed.
