Old 31-08-2016, 04:55 PM   #1
Qwerty321
Qwerty321's Avatar
Default Broken Headlight Retainer Clip
The metal wire clip that holds in the low beam bulb in my right hand headlight is broken and so the beam is now all over the place as the bulb is no longer secure. Any idea how I go about fixing this?
Can I replace the clip itself and also is it possible for me to remove the headlight assembly (not XR style) easily without removing the bumper?
Project/Fun Car - BA MkII Fairlane Ghia
Daily Driver - Volvo V50 2.4
"If in doubt, flat out" - Colin McRae
"Horsepower is how fast you hit the wall. Torque is how far you take the wall with you"
"Cheap, fast and reliable. Pick Two"
Qwerty321 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2016, 04:59 PM   #2
BOSHOG
avenge me
BOSHOG's Avatar
Default Re: Broken Headlight Retainer Clip
theyre for sale on ebay, easy fix
FULL OF Autotech GOODNESS!
BOSHOG is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2016, 05:30 PM   #3
In the meantime, just secure it using a cable tie till you get a new one.
Old 01-09-2016, 01:01 AM   #4
Qwerty321
Qwerty321's Avatar
How would I go about removing the headlight assembly so I can get a good angle and do it outside the car?
Also what would I search for on ebay? I tried searching for Ford BA Headlight retainer clips and got no good results
Old 01-09-2016, 01:48 AM   #5
barrys123
barrys123's Avatar
Any wrecker will sell you one.
barrys123 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 09:55 AM   #6
Madaya
Madaya's Avatar
My clip came adrift (my fault). My bulb is held in place with a few blobs of silastic Still easy to remove without too much force. Replacement of the clip will have to wait until I get around to removing or replacing the headlight.
2010 FG XR6 I6 CC Ute, Nitro colour. lsd, sports suspension, Ford 18's fitted with Michelin Primacy 3 ST 245x45x18, MW Quick Shifter, Pacemaker 4500 Extractors, Carbuilders Soundproofing, KPM Street Fighter CAI
Madaya is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 09:20 PM   #7
Qwerty321
Qwerty321's Avatar
yea I managed to pull a clip off a wrecked ba falcon at my local junkyard. Now it's just a case of actually swapping the clip and it sounds like the headlisght assembly is going to be a ***** to remove
Old 02-09-2016, 12:44 AM   #8
mik
mik's Avatar
yea I managed to pull a clip off a wrecked ba falcon at my local junkyard. Now it's just a case of actually swapping the clip and it sounds like the headlight assembly is going to be a ***** to remove
your not alone mate with the difficult headlight removal , i probably shouldnt say difficult , its not difficult on my s2 xr6 ....... its labor intensive , have to take the stone tray off and nose panel to get a head light out .
Old 02-09-2016, 09:31 AM   #9
Qwerty321
Qwerty321's Avatar
Might just use some zip ties and rig something up until my next wof at which point ill fail and be forced to properly fix it anyway haha
Old 03-09-2016, 07:11 PM   #10
Qwerty321
Qwerty321's Avatar
Okay I've rigged something up with zip ties so that the beam is somewhat acceptable and safe to drive with, but from the looks of it the broken clip is not the real problem. Yes the clip is broken, but that's not why my beam pattern is so off. From what I can tell the headlight adjustment is broken, cause I turn the screw/knob to adjust the beam and it makes absolutely no difference. The knob has little resistance and I can see no visible movement at all in the reflector and/or the light beams.
Old 03-09-2016, 07:45 PM   #11
uniacidz
uniacidz's Avatar
Time for a new set then or good second hand
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
