24-07-2016, 09:02 PM | #1 | ||
vbvbvb088
Have exact same car and did this...be gentle when removing the speedo cable and attached speedo gear. Place to side and fill up. The drain bolt easy as to access however mine was so tight not even a brute could not remove it. In the end used a impact wrench which zipped it off in microseconds.... also car must be perfectly flat and level.
