![]() Join Date: Mar 2007
Hi all,
After some knowledgeable advice from those in the know (again!). As a result of an increase in chances of less than desirable people in our area, we have been considering a home security system (cameras) for a while. However, last week we had evidence that someone had been in our back yard and had entered our shed. Luckily nothing was taken. But, it did put the wind up both my daughter and SWMBO. So, SWMBO is keen to get a system installed. I did some research of these systems (eg Swann) some time back, and the thing that put me off was that a power source (socket outlet) was needed nearby to where each camera was going to be placed to power it. This requirement would obviously add a fair amount to the overall price for installation, depending on the number of cameras you install and the placement of those. I found it surprising in this day and age that the systems did not utilise the one single cable providing the video signal back to the base unit to also carry the power requirements for the camera. So, my question is, does anyone know of a system whereby each individual does not need to source its power from a nearby socket outlet? During my research, it was amazing how many times you read that the cameras are "wireless" but when you read the specs, it is the video feed that they are referring to and not the power supply ![]() Any advice greatly appreciated.
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
Where to next??
Get a pro to go through it with you.
And for goodness sake get decent cameras that can make out a face or a number plate. A neighbor was broken into and all we could make out was that it was a white Holden duel cab ute with a yellow plate. Couldn't make out the plate nor the face even with a plethora of cameras right around where they broke in. Waste of money..... If you are going to spend money make sure it will go to good use some day.
___________________________ I've been around the world a couple of times or maybe more....... |
if you get the next series up in swann they are powered over the ethernet cable so you only have to have the one cable unless you get the cameras that can move and zoom
If you are looking at an alarm system (I know you said cameras) which has an auto dialer (phone line to call out) get a mode 3 socket installed to the first socket or get it wired before the first phone socket (check the a2a first on legalities) because that will isolate the phone line and dial out, as opposed to a theif simply taking a phone off the hook to block the line to the system. Any competent security installer would do it out of instinct, but it's something to think about
I used a Swann in my old house and the only power it needed was to power up the DVR.
The camera run through coaxial cable back to the DVR. You also ran a ethernet cable to the DVR which allowed you to view on your smart phone or table. Easy to install yourself. When I sold the house i took the system with me. I have now changed systems and going with IP cameras 3/4MP running CAT6 cable. This time I'm leaving it up to the pros. Yes it's costing me more but viewing guilty will be worth it |
![]() Join Date: Jan 2005
My mate has installed these at his place - it all runs off POE, and image clarity is excellent:
http://www.ebay.com.au/itm/Hitek-2X-...-/321900784451 http://www.ebay.com.au/itm/4CH-960H-...-/321697211964 http://www.ebay.com.au/itm/121657171...%3AMEBIDX%3AIT You just need some CAT6 cable to hook it all up.
POE, power over ethernet
Ran the cat 6 cable myself Had the pro come in with a system and connect. Saved 3k Got one with 3tb hard drive and 8 cams Records between 4 weeks to 2 months depending on settings. (Surprising how handy thay is when step daughter tells tall stories) Can spot the Mrs coming home across the park (5 houses away), great night vision also. Or can expand the view/vision and read what the kids are !!!!! Still, it cost $4,500. Name escapes me Advice, needs to be accessible to you, not others (behind a locked door/cupboard Get a battery back up (if they turn off your power you record 0 ! )
Ford LV2 Focus XR5 MODIFIED ![]() |
#8 | |||
jaydee351 4DV8 |
