26-01-2016, 06:48 PM | #1 | ||
Hi all
Since sunday we're having troubles starting my Wifes LW2 diesel focus. Sometimes it starts with no trouble, sometimes kicks over for a bit, starts and then stops a few seconds later. Had RACQ put the other morning and he said battery good and thought maybe bad fuel. Once warm, not a drama in the world. It had a service a couple of weeks ago (60k), so will call them in the morning. The father in law reckons water / air in the fuel line due to the fuel filter not being tightened enough and its sucking stuff in. Has anybody had this issue too and what was the culprit? Cheers Dan |
26-01-2016, 07:12 PM | #2 | ||
on some of the TDCI models the fuel line going to the pump on the head is transparent so you can see if there is a bubble in it. If so its the problem it sounds like you ahve an airleak over night which means they may not have put/ damaged the rubber O ring back on the fuel filter cap.
26-01-2016, 07:49 PM | #3 | |||
Thanks for your help Dan Sent from my SM-G900I using Tapatalk |
26-01-2016, 07:53 PM | #4 | ||
It is a ***** to get rid of the air when changing the filter
26-01-2016, 09:10 PM | #5 | ||
I'm taking it back to the service shop for them to do it
27-01-2016, 07:10 PM | #6 | ||
Petrol fuel by mistake?
27-01-2016, 07:28 PM | #7 | ||
28-01-2016, 07:07 AM | #8 | |||
06-02-2016, 02:20 PM | #9 | |||
All good now. Phew Sent from my SM-G900I using Tapatalk |
