Walking with God
I have one stripped wheel nut. The thread on the bolt looks almost salvagable, but the nut itself is trashed! How do I go about fixing it?
I was thinking that SuperCheap or Repco would have a kit, and I would use those locking grips to twist the old bolt out and screw the new one it. Then just apply the new nut! This sound about right? GK |
#2 | |||
Cheers Simon |
they call me Tibbo
front or rear? they just press in from behind
#4 | |||
AFF's 1st DM.......
you have to whack the stud with a drift. you may be able to do with without removing the disc . then the new stud will get hammered in from the inside of the hub outwards.
The studs come with tiny splines and the head is flat n larger. no chance trying to twist it out sorry mate
Walking with God
Thanks for the replies fellas. I'll get it seen to this weekend.
GK |
get a new set of nuts!! not hard
