does any one have a pic/drawing of where all the vacume lines go on a series 3 xr8?
cheers |
Chairman & Administrator
Which vacuum lines? The HVAC ones, underbonnet ones?
Cheers Russ
Observatio Facta Rotae
yeah all the small ones that come from intake and also the stuff for the charcoal cannister.
cheers |
Try this ....
cheers its more the engine side i need as i brought a xls ute rolling shell and put a 220kw v8 in it just trying to get it all plumbed in.
cheers |
You asked for the carbon canister which is why I used that one - can you try to be specific as we can't read minds. Not a lot of diagrams but here are a couple are a couple I found.
Russ
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I knew you would say that
![]() UK
sorry where does the vac line go that come from the fire wall? and what connects to the 2 outlets at the front and rear of the upper intake?
cheers |
