Hi everyone,
I have an AU 2 XR8 with an FG front brake upgrade kit (322mm). It has standard AU rear brakes. I want to put stainless steel brake lines on it. My question is are the BF-FG lines and threads etc the same as the twin piston AU brakes. If so can i just buy an AU stainless brake hose kit and fit it? |
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I have put BF XR 322 on my AU and used the standard AU XR8 on mine they just make the length, I bent the cable holder on the shock a little bit, they still have movement when the wheel is full turned. Haven't fitted the rear so can't help there.
UK
Thanks. Thats positive.
Also are the rears on AU and BF the same? Meaning could i buy a BF+ kit? |
Here you go
![]() UK
Thanks. Which rears are you using?
I'm looking at Terry 328*26 but not sure if they are worth it. Standard BA rears are a bit larger and cheaper to fine.
UK
Thanks. Do the BA brakes require any mods like the BF rears do?
No I dont think so BA's are smaller, only 303*16. They should be an easy swap with 17" mags and above
UK
