Old 08-04-2015, 07:51 PM   #1
Dustproof
Dustproof's Avatar
Default New noise
I have a series 2 LV TDCi with Auto. Lately I am getting a noise that could be considered as Turbo whine, it sounds like a police siren and increases and decreases with throttle response to a point. The car is not lacking power but this noise is just creeping in and I can't explain it. I had the Auto serviced at 60,000km's so I am unsure if it might be in the transmission. Normally Turbo whine is higher pitched than this noise - just weird.
Has anyone had a noise like this with their TDCi Auto?
Thanks
Noel
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2015, 08:06 PM   #2
marg99
Default Re: New noise
is it a pulley bearing? The idler pulley or waterpump bearing noises will increase with RPMs
but your KLMs are a bit low for water pump issues.
Old 08-04-2015, 09:54 PM   #3
DZFord
DZFord's Avatar
Probably the alternator. Mine made the same weird whining / police siren noise, that increased with throttle, back in 2011: http://fordforums.com.au/showthread.php?t=11325474
Probably had around 60-70,000km on the clock.
Old 08-04-2015, 10:42 PM   #4
GTLEGEND
Remove drive belt and run engine for a short period. If noise is gone, you know it is something driven by the belts, if it is still there it is something internal. Relatively easy test to try....
Old 08-04-2015, 11:14 PM   #5
Ratmick
IT Drone from Sector 7G
Ratmick's Avatar
I have the same car, mine has what sound like a resonant momentary high-pitched whine at around 2000rpm which disappears when you're above and below. Happens in any gear under load.
Mine is a 6sp manual though...
http://fordforums.com.au/showthread.php?t=11353588
Ratmick is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2015, 06:49 AM   #6
Dustproof
Dustproof's Avatar
Thanks guys, it seems noises are not something unnatural. I have to service the car soon so I will check it out whilst I am in there. My wife drives the car to work all the time and suddenly they other day when I was driving it, she say "Oh yeah, it's making this noise" hurrumph! why didn't you say something earlier... ahhhh!
Old 18-04-2015, 06:58 PM   #7
Dustproof
Dustproof's Avatar
I had the service done and nothing found except a kink in the air intake hose. The sound appears to be coming from the Turbo, if I stand on it the sound goes high. Not too sure what might be the problem, maybe there is a pressure leak somewhere. I does it when free revving too, it take a bit of foot pressure to get it to do it. I am going to have a good look tomorrow.
Old 27-04-2015, 05:20 PM   #8
Dustproof
Dustproof's Avatar
Found the noise is coming from the Turbo, now to figure out if it is terminal or something silly.
