22-03-2015, 05:09 PM | #1 | ||
I just went and filled up my mower fuel container at the same time as filling my car.
Filled both with E10. Now i'm wondering if its safe to use in both the push lawn mower (briggs and stratton) and the ride on mower (also briggs and stratton)? Both of these mowers are only 2 years old. Will E10 be strong enough to cause any damge to fuel lines etc??? |
22-03-2015, 05:15 PM | #2 | ||
Experienced Member
E10 will be OK, read the article from supplied link.
http://www.briggsandstratton.com//us...ecommendations Cheers |
22-03-2015, 05:22 PM | #3 | |||
22-03-2015, 06:48 PM | #4 | ||
No chance at all that e10 will damage your mowers.
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
22-03-2015, 08:46 PM | #5 | ||
PURSUIT 250
was shown at ryde city mowers what the rubber seals and other gaskets look like after being left in e10. told me unless i want to see them more often to use better fuel. now i use 98 and the mower goes great
22-03-2015, 08:54 PM | #6 | ||
Thailand Specials
My mower gets 98 as well but only because thats all that goes in our cars
22-03-2015, 08:54 PM | #7 | ||
carwant.com.au
I was also told at a mower repair place not to use E10 as it dries out the fuel lines. Not sure if it's true or not, but the mechanic said they are a lot cheaper fuel lines then cars and will dry out then crack...
2 users like this post: |
23-03-2015, 06:27 AM | #8 | ||
Hi. I cant see that E10 would be a problem in a mower that is being used on a day to day basis but I would be wary of using it in any motor that may be left sitting for more than a couple of weeks as moisture in the air may turn the ethanol to jelly. Cheers MD
23-03-2015, 09:04 AM | #9 | ||
Trev
98 is bad in any engine of the stationary or mower type generally. Burns too hot. Honda four-stroke stationary engines can be totally rooted after just a tank or two of 98. Also, you might be interested to know that low compression engines will make better power and torque on 91 than 98. Even the Ninja 300cc Kawasaki machines raced in a beginners streetbike class at the Australasian Superbike Championship found this out, those running 98 got hosed down the straight, those running 91 were fastest... Obviously everyone now running 91... In all my mowers, chainsaws, brushcutters etc. I run 91 only, and personally would not put any ethanol mix in them as I see no reason to run anything but 91. As most workshop mechanics will recommend.
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
23-03-2015, 09:49 AM | #10 | ||
carwant.com.au
Now I'm confused... maybe I will just go half way and use 95, as I only use the mower once a fortnight at best and longer during winter
23-03-2015, 09:50 AM | #11 | ||
Trev
Make it 91, do your engine a favour and save a couple of bucks too.
23-03-2015, 09:52 AM | #12 | |||
PURSUIT 250
This is why I'm a carpenter. Motors annoy me. Might start trying to find 91 without ethanol. |
23-03-2015, 10:22 AM | #13 | ||
I've been using 95 in the Briggs and Stratton because I have one fuel container for all the power tools and they recommend not using ethanol in 2 strokes (slasher, hand mower etc) and none of the local servos have 91 without ethanol. I guess, like a lot of people, I don't have much choice. Apart from that, the handbook for the tractor says ethanol is OK and to use "regular" fuel 87 RON upwards.
23-03-2015, 10:45 AM | #14 | |||
Big Member
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing Rollin' on genuine ELGT wheels. K&N Filter /////Alpine Sound. EBGT Momo Woodgrain Steering Wheel The Scarlet Fairlane Build Thread Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies PWK Build Thread 1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile. |
23-03-2015, 12:50 PM | #15 | ||
The one and only
Pretty sure the servo's selling the E10 recommend you don't use it in mowers, jetski's, etc.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
23-03-2015, 12:59 PM | #16 | ||
been using E10 in my ride on since I got it new in 2011
It says in the Book E10 is OK it says on the fuel cap E10 is OK
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
23-03-2015, 03:41 PM | #17 | ||
my dad used e10 in my boat and killed the inbuilt fuel gauge window, melted it and went yellow, but you would want to have a water separator fitted if you plan on leaving any fuel in the tank for more than a few weeks, over winter drain the tanks so it doesn't settle
i will only use 98 in my push and ride on mowers but they will also run fine on 12 month old 98 fuel which is a bonus
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
23-03-2015, 05:04 PM | #18 | ||
Hey all,
I actually work for Briggs and Stratton Australia as a Mechanical Engineer. E10 is fine in Briggs engines. 98 is not recommended. Use either 91 or 95 for these engines. My preference is 91 non E10 stuff.
Toy: XT GT replica, 393 Windsor, Victor jnr heads, 950 prosystems carb, toploader, 9inch detroit locker with mark williams axles... Daily: EL XR8 manual, GT40P, AU 220 cam T/B & MAF, explorer manifold |
23-03-2015, 06:33 PM | #19 | |||
McNews comments about the low compression/stationary engines are also very true. |
23-03-2015, 06:41 PM | #20 | ||
I run the weed blower at work on paint thinners and it goes fine
1987 Fairmont Ghia - Sahara Gold |
23-03-2015, 09:35 PM | #21 | |||
24-03-2015, 02:22 PM | #22 | ||
E10 will make the plastic fuel lines go hard and crack on older models.
I have replaced them on both my whipper snipper and chain saw due to E10
1940 Ford Deluxe Hotrod 1956 Ford Mainline 1958 Ford Customline 2002 Ford Explorer I only drive V8's |
24-03-2015, 03:04 PM | #23 | ||
i prefer to run standard 91 in in mower, most summers once the hot weather hits i park the mower up when the grass dies off , often dont use it again for sometimes up to 3 months ( no rest this year .... an unually wimpy melbourne summer :( ) , i still think e10 is more of a water attraction fuel ,
so that is my reason for using unleaded. i might add i diligently always leave the the fuel tank full to the top when i finish mowing and even after 3 months of no use........ a few tugs of the starter and away she goes because almost no fuel has condensed in the bottom of the tank and no corrosion with it.. |
24-03-2015, 04:07 PM | #24 | ||
Sounds like its worth adding some fuel stabiliser to the fuel container/jerry can before filling any mower or small engine.
I reckon its worth doing if the mower is going to sit for a few months idle? |
24-03-2015, 04:35 PM | #25 | ||
My mower is just coming on 35 years of age (Rover with a Briggs & Stratton 4 stoke engine). I've run it on Super/98 since day one & it's never required any mechanical repairs & runs/starts perfectly. I have a 900M2 corner block - so it has to cut a reasonable amount of grass, especially in spring/summer when the couch just goes off & needs a weekly cut.
24-03-2015, 05:26 PM | #26 | ||
I always advise, especially with two stroke micro engines, to once finished, drain the tank, then start the engine and let it idle till it runs out of fuel. That means the fuel line and carby is drained of any fuel. E10 tends to "go off" or attract water easier than other fuels.
Had a few guys come to me saying that their trimmers/blowers etc dont start or dont run very well. My first response every time is to try fresh fuel. Nearly every time that fixes it. The Briggs fuel stabiliser works very well with keeping the fuel fresh for long periods of time. My tips; - Always use fresh fuel or fuel stabiliser. - Empty tank back into jerry can and run machine till it runs out of fuel (mainly for micro engine two strokes). - Use 91 or 95. - Check the condition of your fuel line/filter every 6-12months I have also heard of (through the motorcycle scene) that the additives in 98 eat away at certain types of fuel line (neoprene) :|
24-03-2015, 05:30 PM | #27 | ||
VFII SS UTE
older mower I wouldn't use E10.. alloy carbs, brass jets to much work cleaning the barnacle's off..
95/98 only; as I have trouble getting strait 91.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
