Old 14-02-2015, 05:03 PM   #1
gS-Gstar
Default Cam Shaft Syncroniser replaced correctly?
Replaced the cam shaft sycnroniser in my AU falcon yesterday (V8 windsor).
Is there any easy way I can tell if I did it correctly? Car seems to be running fine and sounding the same as it always has, minus the cam shaft sync whinging when I put my foot down.
I was thinking of getting a mechanic to have a look when I take it in for a service.
I'm a little worried because it wasn't until after I replaced it that I realised that I needed to have the engine on the compression stroke when on TDC and that it could be 360 out. Anyways it seems I may just of gotten lucky, but I was reading that just a minor degree out from TDC can have consequences.
I took it for a good run on the freeway with no dramas, around 150kms.
gS-Gstar is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2015, 08:20 PM   #2
gS-Gstar
Default Re: Cam Shaft Syncroniser replaced correctly?
Well, she's still running fine .
Old 20-02-2015, 12:08 AM   #3
martos
martos's Avatar
Sounds like you nailed it lol.
martos is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2015, 10:27 AM   #4
XR Lita
XR Lita's Avatar
Mine runs fine after I replaced my synchroniser too ... apart from the hesitation from a standing start. Might have to pull it out and start again
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2015, 12:41 PM   #5
gS-Gstar
Mine also has hesitation but I never really noticed it until I read it on here. Regardless, it was doing it long before I replaced the cam shaft sync.
Old 03-03-2015, 11:06 AM   #6
pete05
pete05's Avatar
Have a look in my build thread I have a few pictures and some discussion on it.
http://www.fordforums.com.au/showthread.php?t=11429552
AU11 xr8 manual
pete05 is offline   Reply With Quote Multi-Quote with this Post
