Turbo Falcon Fiend
Hi folks,
I gave in. I put a 71 degree thermostat in may car the other week. Why so cold? Because I fugured that cold engine meant less heat soak means more power. My plans were dashed when the engine got quite warm. This was the time I blew a heater hose and did my bush mechaic repair on the side of the road. So I took it out and went back to no stat. Now with the hot weather my car gets warm when I accelerate too much or run boost for too long and when the A/C is on, other than that it is fine. It could idle in traffic all day with the A/C flat out. So what next? Anyone have any suggestions for how I can keep the car cool ? Would using the recommended stat make any difference? I hate having to drive home at 90-100k's to keep the temp down! |
give it a try... it should work because it is reccomended regardless if u have a turbo or not.
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
Fantastic Plastic
did u reset the ecu when u put in the thermostat ????????? - this could be the cause of your problems - with any modification or change in engine specs / whatever .... the ecu should be reset so the rest of the system/motor can adjust itself to the new settings or parts.
Turbo Falcon Fiend
But the stat is a heat controlled device?
Fantastic Plastic
Yeah the stat is heat controlled, but alot of the other stuff on the engine that is ecu controlled runs accordinglly to the engine temperature too , im NOT saying that reseting the ecu will fix the problem , but they way everything else relies on each other in these new engines these days, it might definatelly be worth a shot an might fix the problem .... just a suggestion . ;) , good luck
Turbo Falcon Fiend
OK. Anything free is worth a try!
#7 | |||
Back on the road
Going too cold with the thermostat could leave the EEC in "Cold Start" mode. It runs alot richer because it thinks the engine is cold, kinda like running around with the choke on. Are you sure your engine is running hot and it's not just a dodgy temp sensor? At least put the stock thermostat back in until you find out what the real problem is with your cooling system. Running with no thermostat is baaaaaad...mmkay.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
Turbo Falcon Fiend
Why bad Mr Mackay?
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
Back on the road
It takes much longer for your engine to reach operating temperature because the thermostat is normally shut while the engine warms up.
Your engine wears much much quicker when it is cooler than operating temp :(
Fantastic Plastic
XR8UTE ....quoted "Going too cold with the thermostat could leave the EEC in "Cold Start" mode. It runs alot richer because it thinks the engine is cold, kinda like running around with the choke on." ...........
That is the exact reason why i said for maybe trying to rest the ecu , a really rich fuel mixture or something of that sort ( or other things ecu controlled effected by engine temp ) could be causing something as a mislead engine temp by the ecu - thus causing other ecu related parts on the motor to which have to do with temp to be misread. |
Fantastic Plastic
by the above, clearing up what i meant, is that the car/ecu could actually be thinking that now after suposablly warmed up with the new thermostat that it actually hasnt warmed up because the fuel system and other parts are relying on setting their settings to the original older hotter temperature . Yeah it reseting the ecu might make the car think it hasnt warmed up , but it may also passed it as warmed up , then allow it to set the new running condition temps for the fuel / air mix and so forth , nothing to loose in trying it , can allways just reset the ecu again if it doesnt work , and its something free to try before spending $$
#12 | ||
Back on the road
Yep, I can see your point. However the adaptive fuel strategy is really just for fine tuning idle, cruise and some part throttle. Fuel enrichment strategies like cold start would be unaffected.
Certainly not going to have an impact on an engine thats overheating when driven hard. Assuming its not just a simple issue with cooling capacity, it may be worth getting a radiator specialist or similar check over your cooling setup. Make sure theres nothing simple like a radiator cap not holding pressure or a buggered water pump or whatever... Have you got any heat shielding around your turbine housing/dump pipe? Maybe just heatsoak from the turbo install rather than a cooling system issue..?
#13 | ||
Fantastic Plastic
XR8 ... lol yeah thats a good point too...quoted "Make sure theres nothing simple like a radiator cap not holding pressure or a buggered water pump or whatever..." , i forgot all about the little things like that , more than likelly something like that - ....or -- i dont know if its possible on new cars cos i havent changed a thermostat on 1 yet , but in alot of older cars it was possible to put it in BACKWARDS (inwards faceing out and vise versa ) accidentlly and this would cause the above proplems !!!!!
#14 | ||
Smile
Turbo taxi I know im NA in my AU six ..but I ran a cooler thermostat some time ago.I found that while the car had better power for a while but the plugs fouled up easier and chewed alot more fuel.The cars ecu thinks it is still warming up and makes it run too rich.Heatsoak really kills all 4.0 sixes but running a proper thermostat avoids other hassles
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#15 | ||
Last warning
the problem is, once the cars upto temp, the thermostats open almost all the time anyway.
running a colder thermostat will only delay the car getting to that full operating temp. i'd be looking at things like airflow to radiator or other blockages.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#16 | ||
Turbo Falcon Fiend
I will fit a standard stat and perhaps flush out the radiator.
I will check every where for air/water blockages.
#17 | |||
Ferret
#18 | |||
Smile
#19 | ||
Back on the road
To get the best result you should have the thermofans set to switch on at the same time the thermostat opens so they can work together to keep the engine temp stable.
#20 | |||
Back on the road
They are tables that store the learned corrections (as percentage), to be applied to the calculated injector pulsewidth, to achieve an AFR of 14.64:1 during closed loop. I think the tables are 2D load x rpm??
#21 | ||
meh , i was going to do a cooler thermostat but its going to be winter in a few months...
James |
