11-11-2014, 09:22 PM | #121 | |||
disconnection can be the same day, or could take weeks, all depends on where the team is and how busy they are, suburbia can be quick, country can be slow. as for meters it varies .....we've had some meters taken away and others left behind. they do, however, remain the property of the power distributor so you can't use them to meter your usage. the line is simply diverted ( power company isn't interested once it is disconnected) from the infeed pole to the new power source. your sparky will have to make the connection to the new source through your fuse panel.
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
12-11-2014, 12:04 AM | #122 | ||
Performance moderator
I would LOVE to have twice the solar I have now.. Going off grid is easy.. I'd like to see them tell me I can't do it!! If I don't pay ?
They disconnect anyway.. Done!! Thank you !! A few things need to change though Limit usage after sun goes down.. Like toaster, electric jug.. Or anything over 1200 watt for any time.. I can see a time where elect supply companies are going to try and keep there customers.." Keep charging" ... Bayching power.. There are alternatives..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
12-11-2014, 12:23 AM | #123 | |||
Experienced Member
It is no simple process as portrayed by some here. |
12-11-2014, 12:58 AM | #124 | |||
It might be difficult, and what utility isn't difficult to divorce from? but it might not be that difficult, some paper work and the will to disconnect. But it can be done. I think that has been proven enough for these discussions I don't see why your so hooked on it, why the bugbear? the hurdles you put in your own way. JP |
12-11-2014, 01:24 AM | #125 | |||
Experienced Member
I'm not saying this cannot or can be done, I'm just questioning it as I'm under the belief government regulations has changed regarding this topic I have sent a query to Energy Safe Victoria on this subject & wait for answer. No I'm not hooked or bugbear just curious for a positive answer if any. |
12-11-2014, 11:44 AM | #126 | |||
Arranging the meter to be abolished is easy. Contact your Energy retailer and ask what is required for abolishing a meter. They will say a VESI form, and depending on the retailer, they may ask for proof of ownership such as rates notice etc. They may also ask for you to complete their form. Download the VESI form from below link. http://www.unitedenergy.com.au/media..._supply_v2.pdf Complete the VESI form and any other required forms and send to the retailer. Retailer will submit to Distributor and the Distributor will attend usually within 20 business days and remove supply line and meter. You will then not be connected to the grid. They may charge you for this service, speak to your retailer before completing this. The retailer does not need to know why you are abolishing the meter. |
12-11-2014, 12:39 PM | #127 | ||
I posted one of those links previously. True blue has obviously been told something different in the past. Be interesting when he hears back from Energy safe Victoria.
12-11-2014, 01:13 PM | #128 | ||
Interesting to find out the answer considering I arrange meter to be abolished on a daily basis.
12-11-2014, 03:05 PM | #129 | |||
Experienced Member
The link you provided for that form clearly states premises to be vacated & that part is a mandatory requirement to be filled out. When I do get an answer from ESV I will post up, whenever that will be from them. |
12-11-2014, 06:06 PM | #130 | |||
13-11-2014, 04:16 PM | #131 | ||
BANNED
A simple how to for you budding off gridders...
For those of you contemplating going "off grid" bear in mind that the inverter units that are currently employed to grid feed your panels will not suffice. This is because they rely on the grid as a reference for frequency and voltage. However.... If you have been clever and rich enough to buy only SMA grid feed inverters you are in luck. SMA make a device called a "Sunny Island". This clever ($5000 dollar) device will provide the reference parameters to keep all your existing SMA grid feed inverters happy off grid....almost as many SMA inverters as you can throw at it. It will also control the charge of your battery bank for when the sun goes down. It can be programmed to load/dump a hot water system or spa/pool etc etc etc. You can connect your wind turbine to it etc etc etc. Without this device you are screwed...big time. How do I know? cause I have done it. Don't waste your time with the Selectronics unit for off grid, it is incompatible with other grid feed inverters that you already have. If I were a power company i would be seriously worried about my business model with these types of options. |
13-11-2014, 04:42 PM | #132 | ||
been talking to a few boffins on whirlpool who seem to know the goods........a lot of stuff in the pipeline with lower prices to boot.
easiest way so far, that we have found, is to charge the batts using current technologies, (won't use brands as too many arguments ensue) then we run everything off batteries through various inverters. the only drama so far is that folks still want ALL their goodies.
13-11-2014, 05:45 PM | #133 | ||
BANNED
poppa smurf, I can tell you that the latest samsung 280L fridge with the new fangled inverter technology compressor uses less power than my toshiba laptop when on full sing.
and it makes ice cubes in about an hour too! (was the only 4 star rated fridge at a reasonable price ) Also...it was cheaper to buy 4kw of panels and a conventional element hot water system instead of a "solar" hot water system and hook it up direct. Works perfectly with a 2.4kw element...but not a 3.6kw |
13-11-2014, 05:51 PM | #134 | ||||
Experienced Member
This was ESV response to me: Quote:
13-11-2014, 06:05 PM | #135 | |||
JP |
13-11-2014, 06:19 PM | #136 | |||
there is a lot of "inverter" type technologies on the market at the moment......I see Daikin now has 7 star rating, inverter air conditioners...... getting to the stage where it won't be long and all luxuries can be had on solar/batteries. 42 here today......wouldnt want to be without the cooler. just got to get the batteries down to a price and reliability that we can cope with. then we can do without the gennies.
13-11-2014, 06:22 PM | #137 | |||
well I'll take my hat off to you for having the guts to admit when you're wrong, that, to me, is the measure of a man.......... most would have simply gone away. energy companies are still coming to grips with this new line of thinking (going off grid)......
13-11-2014, 07:36 PM | #138 | |||
Experienced Member
Energy companies are not being forthright on info at times, I should have known better then again I been out of the trade for the last ten years, must get back into it again & brush up on the latest regs. Cheers |
13-11-2014, 08:46 PM | #139 | ||
If it ain't broke........
Well we had 2 prices for power to our bush block from Powercor. First one was $170,000, I kid you not, second one, if we got permission from the neighbor, 40k. And that is only to the fence line.......So let's just say I love these threads. Keep the info coming......
Visitors welcome Relatives by appointment only |
13-11-2014, 09:01 PM | #140 | |||
Experienced Member
13-11-2014, 09:15 PM | #141 | ||
About 300 meters to the fence line and no , only Powercor at this stage.......
14-11-2014, 06:24 PM | #142 | |||
BANNED
I just helped a mate in Eildon who needed a 440 metre line. Powercorp quoted 77k. We just went to Middendorp's, bought a 500meter roll of 10mm conductor diameter single phase wire...(the thickest they had) Threw it on the back of my cruiser with a pole through the middle of it. Started at the top of the hill and unraveled it all the way from his house to the meter box down the hill. It needed a 5 tonne bobcat to get the big wooden spool on the ute. It's the pretty orange encased stuff and it weighs a lot. 500 metre roll was 2500 bucks...chicken feed in the big picture. I measured the resistance at 2 ohms shorted out...that's stuff all. We then put a 30amp plug on both ends and loaded it up with his cement mixer, TIG welder, jaffle maker, grinder etc etc. We got 45 amps out of it and the voltage dropped from 239 to 232. WGAF? that's stuff all. Dug a trench and threw it in with some safety tape on top. His house will use solar panels everywhere and can still pump back onto the grid. Piece of cake....Total cost $2700 inc cable, plugs and beer. |
3 users like this post: |
14-11-2014, 10:35 PM | #143 | |||
Experienced Member
I would seriously get a few quotes from sparkys to quote from your neighbours to you, they will give you an idea if voltage drop is an issue. |
15-11-2014, 12:01 AM | #144 | ||
Sparkles tend to be expensive .. Try and find an overhead or underground cable laying company.. He'll at those prices a solar and diesel generator could be run just off interest saving..
15-11-2014, 09:30 AM | #145 | ||
They did I think from memory mention a transformer...... There are a lot of 20 acre blocks in and around our block and I'd say only half have mains power. The rest are self sufficient....
