Adams Polishes
Old 30-01-2006, 03:14 PM   #1
trimmaster
Ford Trim Specialist
trimmaster's Avatar
Question AU1 V8 , sometimes runs on 7!
Does anyone know what could be causing the problem to make my V8 run on 7 or less whenever it feels like it.
Yes, I've changed plugs and leeds and even removed the metal boots where they plug onto the plugs as advised by an ex Tickford engineer. ( to eliminate cross firing).
The problem has ocurred at so many different times that I can't get any history to work it out.
It has done it on start up in winter, turn it off, start it again and is perfect and sometimes still missing. Same in summer, so it's not a hot or cold thing.
It has done it while driving around town at low speeds and also while cruising on the freeway, as was the case on Saturday on the Citylink in Melb. ( for those of you who saw the Blue T series sitting for 2 1/2 hrs with the hazard lights on, only to be told when the RACV guy did finally turn up that I should buy a, well you can guess!! NOT HAPPY! And he didnt even help.
Its been back to the dealers a few times, but it never does it then, and of course it never logs a fault code.
Only thing left to change are coil packs, but at the current price I'm not so keen without some proof. Am I missing another sensor?
Occasionally I do press the economy switch but this is rediculous.
Any suggestions? I'd also like to hear from fellow AU1 V8 owners.
trimmaster is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 03:31 PM   #2
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
What km's are on it? What about injectors or wiring to them?Poor connection at one of the plugs to the injector.Maybe??????
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 03:41 PM   #3
trimmaster
trimmaster's Avatar
The problem has been there since 60,000km and is still there now at 85,000km.
I change the fuel filter every 10,000.
I like your idea about the injector wiring and will check. Doubt it will be a dirty injector but thanks for the tip.
Old 30-01-2006, 08:01 PM   #4
richardxr8
Plugs and/or leads ! But youve already checked those.... Maybe check em again to be sure ?? If/when its missing, is it always same cylinder ?
richardxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 09:15 PM   #5
Jeld-Wen Falcon
Jeld-Wen Falcon's Avatar
Sticky valves?
Jeld-Wen Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 07:59 AM   #6
trimmaster
trimmaster's Avatar
Have visually checked leads and removed plugs, all OK. If it was a sticky valve or stuck lifter then it would make a heap of noise? No noises.
I don't know which cyl/s it drops as when I take it to the dyno it won't do it.
I wish it would log a code, any Ford trained mechanics out there, can you tell me how much info do these things store, and how mmuch can be retrieved?
Old 31-01-2006, 01:04 PM   #7
FASTXR
FASTXR's Avatar
I sincerely doubt that this is whats wrong with yours, but I had a bad miss in my AU1 XR8. Replaced plugs and leads and it was still running rough, moreso at higher speeds (ie 70kmh or higher).
Turns out the problem was a stuffed engine mount, and the harder the engine worked the more noticeable the vibration. Once I figured it out it made perfect sense, but it did feel exactly like it was running on 7 cylinders.
Good luck with it.
FASTXR is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 05:27 PM   #8
trimmaster
trimmaster's Avatar
I'll check the mounts but that same day when it ran ok again I was able to cruise on the freeway at 110 with no probs.
Like I said it will happen more than once in a day, for a couple in a row, then no probs for weeks.
Old 02-02-2006, 04:17 PM   #9
trimmaster
trimmaster's Avatar
Well I've been checking everywhere, things like plugs and wiring and found the wiring/plugs to injectors 5 & 6 both are broken. Seems someone has unplugged them at some stage and broke them in the process. This means that the plugs dont lock on and can move.
Maybe this is whats been happening.
Its going on the dyno tomorrow, so will test this theory.
Old 02-02-2006, 04:19 PM   #10
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
There's been two guys here that have had their V8's drop to 7 cylinders and both times it's been a broken valve spring...
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2006, 04:23 PM   #11
Stav
Smile
Stav's Avatar
Have you cleaned /check the pcv valve? Did you think that the leads may be crossfiring when the engine bay heats up?Has the throttle body been removed and cleaned?
