Old 13-06-2014, 05:07 PM   #1
b2428
Default MA diesel service.
I bought my car at 37000kms I have had no service books. It is coming up to service time at 85000kms having been serviced at 10000km intervals up until the last 1 that was at 15000km. Of course give or take a 1000. I have a few questions now.
1.In the past I have serviced all my cars. Only thing I havent done is transmission services. So will the car be looked at in a bad light if I do the service myself come sell time?
2. Given I have no service books is it possible for anybody with a scanner to scan a few pages so that I know what I need to do for each service. This would be greatly appreciated.
3. Does anybody have any recommendation for a decent priced oil. For example in the past I have had bad results with the BA with Penrite. This lead to a stuck lifter so have no only used Magnatec. Good priced seems to work well. SO what do people recommend for a Mondeo diesel.
In the garage
2010 Triton GLX-R Dual Cab. So good to be back in a manual.
2008 MA TDCI MONDEO, recently became somebody elses problem haha.
1988 EA Fairmont Monza Red 3.9L CFI - the project beast. On hold for now.
2013 Nissan Pulsar ST-L - The better halfs car
b2428 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2014, 06:31 PM   #2
russellw
russellw's Avatar
Default Re: MA diesel service.
I assume it's the 2.0L Duratorq.
Recommended oil is to WSS-M2C913-B Specification.
Service info changed at 6th month 2008 build but I'll assume it is the earlier one.
Info below is for the 85,000 km service.
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and horn -Check operation
Washers, wipers - Check operation/adjust, if necessary (where applicable)
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination - Check operation/condition
Handbrake - Check operation/adjust, if necessary (where applicable)
Service interval indicator - Reset
Seat belts, buckles and stalks - Check operation/condition
Odour filter - Renew
Outside Vehicle
Hood latch/safety catch & hinges - Check operation/grease
Emission test Check regarding next emission test due - if applicable
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines - Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator - Check for damage and leaks
Coolant expansion tank and washer reservoirs - Check/top up fluid levels as necessary
Battery terminals - Clean, if necessary/grease
Battery Visual check for leaks
Fuel filter - Drain water, if not renewed - Diesel models (with drain facility)
Headlamp alignment - Check, adjust alignment, if necessary
Brake fluid - Check/top up fluid levels as necessary
Under Vehicle
Engine Drain oil and renew oil filter
Steering, suspension linkages, ball joints, sideshaft joints, gaiters - Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle - Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust - Check for routing, damage, chafing and leaks
Underbody - Check condition of PVC coating
Tyres - check wear and condition, especially at tyre wall
Brake system - With wheels/drums off, check brake pads, discs, linings for wear and check brake cylinders and drums for condition; check rubber components for deterioration
Outside Vehicle
Engine - Refill engine oil. Reset the oil change indicator, if fitted.
Tyres - Adjust pressure
Mobility system - check best before date on tyre sealant - if applicable
Spare wheel - Adjust pressure, check wear - condition
Luggage compartment lamp - Check operation - if applicable
Wheel nuts - Tighten to correct torque and check for correct type. Check for rim damage
Wheel covers - Check for damages, especially at retainer system
Side door latches - Check operation/grease
Extended Period Maintenance
Brake system - Every 2 years - Renew brake fluid
Air conditioning - Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks
Cooling system - Every 10 years - Drain, flush and refill with Super Plus
Camshaft drive belt, tensioner and idlers - Every 100,000 km / 5 years - Renew
Auxiliary drive belts - Every 100.000 km / 5 years - Renew
Russ
Old 13-06-2014, 07:40 PM   #3
b2428
I'm not 100% sure will have to check if its before or after 6/08, didnt realise the cambelt needed changing at 100000kms. When I was looking into them I was told by the local Ford dudes I was told otherwise. Wouldnt suprise me as they had only seen 2 MC's when I had asked.
In the garage
Old 13-06-2014, 07:42 PM   #4
b2428
Oh and thanks for the info.
In the garage
Old 16-06-2014, 05:31 PM   #5
b2428
Thanks again russ but turns out my diesel is an 09/08 build. So I'm hoping that that means the timing belt will be later.
In the garage
