07-05-2014, 03:37 PM | #1 | ||
Hi i adjusted handbrake on my au wagon yesterday and thought i might add a small comment - apologies for any repetition
to tighten the brakes turn in a clockwise direction (as if looking from above) so if you are working on - -left/ drivers side, tighten by levering toward yourself - right side, tighten by pushing away levering the screwdriver only worked for me when turning toward myself, to turn the other way i gave the screwdriver a small tap with a hammer to turn the adjustor cheers |
11-06-2015, 05:03 PM | #2 | |||
Matakana NZ
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
11-06-2015, 05:13 PM | #3 | ||
hi easyboss,
i wrote that post a while ago, give me a ring on 0428746617 and ill try to explain........... only just realized you are in NZ im in AU, so youd have to ring +61428746617 (i think) Last edited by XYwagonAU; 11-06-2015 at 05:31 PM. |
11-06-2015, 05:28 PM | #4 | ||
you can access the adjustment without taking the disc off
to tighten you turn clockwise- but because of where the access 'window' is, you have to turn it differently on each side, the hole to access adjustment has rubber grommet over it the adjusting wheel has lumpy bits (like castellations) you push the wheel with a screw driver- either levering toward you or pushing away - as wheel is perpendicular to disc (horizontal) get a torch and try to see what is going on it there.. im not sure but i think i jacked both rear wheels off the ground, put vehicle in neutral, handbrake off, turn one of the adjustment screws a bit / then test- you want the brake to come on by 4th click apparently btw - im definitely not a mechanic (any only tried this on AU wagon - disc brakes no IRS) if you dont get any joy you can take disc off then you will see what is going on........... Last edited by XYwagonAU; 11-06-2015 at 05:35 PM. |
11-06-2015, 06:41 PM | #5 | ||
http://www.fordforums.com.au/showthread.php?t=11418260
found this pic on forum..........courtesy - "phildo" also first step is to turn the disc/drum around so that you can find adjustment screw....... |
