Old 18-01-2011, 09:25 PM   #1
Dingo
Ford T3 Partsologist
Dingo's Avatar
Default AU3 XR8 220kW SIGNATURE ENGINE
g'day all would like some help to varify a N.O.S. crate engine that i have, i'm pretty certain its correct but would like some help to varify please any help would be greatfully appreciated - thanx
engine builder ADAM DOYLE, GT40P HEADS modified with Yella Terra gear date stamped july 02, didnt come with the Tickford throttle body was souvenired by a Ford employee
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2011, 10:08 PM   #2
b2tf
not here much anymore
b2tf's Avatar
I havent heard of that engine builder before but that doesnt mean it's not legit.
What aspect of it are you trying to confirm?
2024 F150 XLT
Old 19-01-2011, 12:39 AM   #3
JC
JC's Avatar
July 02 would be last of the AU3 XR8s - probably genuine then.
Ford Performance Club ACT
Old 19-01-2011, 01:36 AM   #4
Dingo
Dingo's Avatar
LOL JC your the reason why i'm trying to varify this engine, some time back you quoted that my engine would likely to be a 200kW and not a 220kW.
do 200kW have GT40P heads ?
Old 19-01-2011, 08:27 AM   #5
b2tf
b2tf's Avatar
Yes they do. AUIII sedans are 220kw models.
2024 F150 XLT
Old 19-01-2011, 09:23 AM   #6
FTE217
T3/Sprint8
FTE217's Avatar
I'll 2nd the above as motors not models hehe.....
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 19-01-2011, 10:42 AM   #7
Sprint347
Tickford
Sprint347's Avatar
Is this the one that's been on ebay for $16k?
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2011, 10:43 AM   #8
4Vman
4Vman's Avatar
What if it was a ute engine...
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2011, 12:25 PM   #9
Dingo
Dingo's Avatar
yup thats the one - didnt sell it, had some stupid offers and wasnt pre-pared to give it away decided to keep it will post pics of it
Old 19-01-2011, 12:29 PM   #10
Dingo
Dingo's Avatar
was the 200kW GT40P heads modified with Yella Tera bitz.
Old 19-01-2011, 12:30 PM   #11
b2tf
b2tf's Avatar
no, the GT40P's on the 200's were not modified - just bolted on.
2024 F150 XLT
Old 19-01-2011, 10:12 PM   #12
Dingo
Dingo's Avatar
here's som pics of the crater ive made a couple of errors in my opening post to this thread, the engine builder is Sam Doyle and the date stamp is June 02
25/06/2002
07/12/2000
Old 19-01-2011, 10:23 PM   #13
Day-mow
rexnet
Day-mow's Avatar
its ok
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2011, 10:52 PM   #14
JC
JC's Avatar
I would now change that and say it's more likely to be a 220, however, as the 200s were going into utes right until the end of the run (Pursuit ute excepted), it's hard to be sure. Have you run the engine number past Ford? They should be able to tell you for sure.
Even the 200s did get RRs, but they would have been 1.6 ratio, whereas the 220s got 1.72 ratio. Though the wrong rcokers have been found on even T3 motors!
But the 220 Auto sticker (ID 320 GA) is probably the biggest clue as to what this is and what it was destined for.
Old 19-01-2011, 11:14 PM   #15
Dingo
Dingo's Avatar
this was purchased from FoMoCo 2004/5 they had 5 of them to be cleared, all 5 were un-stamped never installed to vehicles FoMoCO at the time advised they were AU3 XR8 Signatures - we only purchased 1
wouldn't know where to start at Ford as i have no contacts anymore, thats why im hoping here can help
Old 19-01-2011, 11:25 PM   #16
JC
JC's Avatar
Is there any way you can check the roller rocker ratios? If they're 1.72, then it's highly likely they're the 220 engine.
Old 19-01-2011, 11:40 PM   #17
Dingo
Dingo's Avatar
how would i do that, im only a partsologist with basic mechanical skills LOL
Old 20-01-2011, 07:57 AM   #18
JC
JC's Avatar
Yeh, dunno!
Here are the engine specs for the 220 from the FPV site (http://www.fpv.com.au/theheritage/fa...onxr8-220.aspx):
Engine
AUII XR8 220kW: Windsor 5-litre V8, OHV, electronic multi-point fuel injection, 9.4:1 compression, reworked Explorer GT40P cast iron crossflow heads, roller rockers, special camshaft, cold air intake, low restriction twin exhaust system, 70 mm throttle body, oil cooler, match-ported inlet manifolds,upgraded fuel pressure regulator, 220 kW@5250rpm, 435Nm@4,000rpm.
Old 20-01-2011, 02:46 PM   #19
Dingo
Dingo's Avatar
thanx JC i'll use this info to do some checking with what i've got here, so these engines were used in AUII & III XR8's. Would they have used them in utes as well you reckon ?
Old 20-01-2011, 02:59 PM   #20
Dingo
Dingo's Avatar
found some info on a quik id of yella terra rockers used for 200's & 220's - 1.6 has a circle with a # 6 with in the circle & 1.72's have the circle with no number with in.
Info from Yella Terra (03) 9555 5522
so it's likely this engine has all the right signs to be a 220kW
Old 20-01-2011, 07:34 PM   #21
Dingo
Dingo's Avatar
see the orange paper decal (this orange decal is also on the oil filter and RH R/Cover at the rear) 1D320BA and maybe re-engineered to a 1D320GA as to the purple/mauve decal, could that be the engine ID, like how the XW XY XA D block GT engines had them example CK617J1 ?
Old 21-01-2011, 12:05 AM   #22
Dingo
Dingo's Avatar
Old 19-01-2014, 11:01 AM   #23
Gazza440
MoPar man 11
Default Re: AU3 XR8 220kW SIGNATURE ENGINE
Ive got the same sticker JM 1D320BA code on my AU11 (Nov 01) "FULLY OPTIONED AU111 XR8 UTE.......
Is that cool ??
Gazza440 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2014, 11:27 AM   #24
Gazza440
MoPar man 11
I got this exact sticker on my AU11 Nov 01, Are you starting to love me a little bit ??
Old 19-01-2014, 11:27 AM   #25
Gazza440
MoPar man 11
and its a UTE..... UTE UTE UTE
Old 22-01-2014, 06:07 PM   #26
JC
JC's Avatar
AU3 Utes only ever got the 200kw motor......Pursuit ute excepted
Old 22-02-2014, 05:00 PM   #27
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
