Old 27-01-2014, 11:07 PM   #1
hales231271
hales231271's Avatar
Default AU S2 6cyl Power Steering Rack Pressure Switch
Hi All
Does anyone know if Power Steering Rack Pressure Switch is in the "open"
contact position when engine is not running?
My idle does not rise when turning steering wheel.
Have tested continuity and the switch currently is in an open contact state and does not change when moving steering wheel.
I am sure it is faulty and new unit is required.
They are a pain to change out.
Dazza
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2014, 05:56 AM   #2
peterljohnson55
peterljohnson55's Avatar
Default Re: AU S2 6cyl Power Steering Rack Pressure Switch
FYI, I had mine in November 2012 and here are my notes:
Supply and fit power steer rack switch, o-ring and oil.
Parts $100.30; Labour $50.00; GST $15.03; = $165.33
As you can see the labour component is quite small so if you cant be bothered with the bother get a mechanic to fix it.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2014, 04:59 PM   #3
robertjp
The switch only opens when the steering wheel is on a lock, not for normal driving. But the switch is not that hard to replace, I've filled down the sides of a spanner to be able to get more turns on the nut that holds the switch. Yes it is a pain, but doing it yourself will save at least 50 and more if you dont use genuine parts.
Robert.
robertjp is offline   Reply With Quote Multi-Quote with this Post
