When in doubt, GAS IT!!
A couple of weeks ago I invested a whopping $9.89, including postage, for one of those chinese OBD2 diagnostic scan tools and then downloaded the latest Forscan program to my laptop. When it arrived I went out to the Sportsman and plugged it in. Within seconds it connected to the car and asked me if it was LTD/Fairlane/Fairmont or Forte/Futura/XR! So it recognised the odd hybrid AU setup immediately and started scanning. It pulled up half a dozen old codes straight away and let me clear them then scanned again automatically and pulled up a current code that told me my VCT solenoid was playing up which I duly changed and now I've picked up about 50-60km to the tank.
That little $10 investment saved me a bucket load of cash chasing my fuel economy problem and the beauty of the Forscan program is that it not only pulls the codes and allows you to clear them but the codes it pulls, it tells you what they are and there's a troubleshooting guide to help you track down the problem, AND IT'S FREE!! What an excellent bit of kit. It also does real time logging and other stuff but I haven't played with that yet but even without any of that it's an absolute must have in your AU tool kit as far as I'm concerned, I love it. Just thought I'd share. ![]() ![]() ![]() Bushbasher
12 users like this post: |
AU3 5.0L Fairmont Wagon
![]() Join Date: Mar 2011
I know what you mean, mine actually arrived today but I managed to use AU11LTD's on my ute and did the same as you, scanned it, weed the codes which removed the airbag fault light for me as well ... Such a cheap investment for a great tool to have .
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar Ford Performance Club of ACT [SIGPIC][/SIGPIC]
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Search ELM327 on Ebay.
I agree Bushy, great bit of Kit. As Rayban76 mentioned above, we managed to clear his airbag light with it, so now he has a ute with working passenger airbag. Win Win. I originally purchased it for the real time data that it can provide. As I cannot get a Quarterhorse strategy for my I6, I wanted it to show me how it is running by looking at the short and long term fuel trims. It works great on both my cars, I6 and V8. There is a whole thread on this kit in the AU section somewhere - lots of great advice. Must find and read it again now. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
I did this today myself got the trouble codes ect i tried the key on engine off or key on engine on diagnostics and while it started the test i could tell because the climate control displayed everything it kept saying test failed has anybody got this function to work on forscan yet?
Mine worked perfectly. I just followed the instructions that came up on the screen in the pop up window. Did you put your foot on the brake and turn the wheel when it asked with the engine running test?
It never gave me the option test started after bout 5 seconds said test can't be completed and stopped itself
It says the following
error unable to run test: PCM- key on engine off (koeo) Please make sure test conditions are in place. |
Hold on, I'll go out and plug mine in and see what the test conditions are supposed to be.
Ok,
Vehicle must be stationary and in Park or Neutral Hand brake must be on If your car is manual you may need to depress the clutch during the test Do not activate vehicle switches during the test ... that's what the pop up window says.
alright i did the test and it found these errrors
code:po116-suspect sensor module: powertrain control module not sure what that means and error PO171 system to lean bank 1 then gives 5 possible causes for that error so seems to work pretty well |
#13 | ||
clear the codes and do the test again, They may be old codes.
#14 | ||
Missing a sock...
![]() ![]() Join Date: Mar 2012
Nice to see someone having a win bushbasher - thumbs up champ!
auIILTD - I think you're talking about these threads: http://www.fordforums.com.au/showthread.php?t=11373845 + http://www.fordforums.com.au/showthread.php?t=11326889 Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
#15 | ||
Well I think it is time I purchased a cable (only $8 or something.... http://www.ebay.com.au/itm/ELM327-V1...83b046c&_uhb=1
This may help me figure out what the hell my car has been doing of late...
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
#16 | ||
Mine is a bluetooth one and it works just fine. Cost me about $9.50. I didn't want the cable getting in the way while doing real time logging.
#17 | ||
CNC fixer guy
Hi basher.
I got a usb version from an aus seller for 18 bucks and it arrived 3 days later. Running forscan and it is pretty cool. I ran my au with live data on the scope screen and i like it a lot. It also found a dtc code on the wifes fg hvac unit : B2010 servo motor panel door circuit failure. After i saw the code i noticed the fan would not blow onto the floor position, so gotta mention that to the dealer as its under extended warranty. You cant complain with what you get for so little. If you like diy on your car then get one fellas.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
#18 | ||
Ok so I have received the cable in the mail. I have also installed the Forscan program on my laptop and have now tried to use it. But with no luck just keeps coming up saying that "No ELM found. Please check connection and try again"...
Any ideas anyone? Or is this the issue my car is having? I have tried 4 different scan tools so far and all can see the PCM without any issues but cannot see any other module? What could be the cause of this...any ideas would be appreciated as otherwise it is going to be a matter of pulling the entire dashfloor loom out and checking each and every connection/fuse/relay/module until I find the fault.
Toy Car Build |
#19 | ||
Auto Nerd
I had that problem when I first ran forscan. Try a different usb port if you have one.
For the first time, I had to run the engine for the program to talk to the computer. After that it would hook up whilst the ignition was on reds. |
#20 | ||
For those having issues, try this link http://www.totalcardiagnostics.com/s...-obd2-software
Solved the problem I had, and might help others. |
#21 | |||
CNC fixer guy
You have to install the correct driver for your version of windows first.
#22 | ||
Can anyone post a link on ebay for any OBD unit that will work on an 1999 AU1,
having difficulty finding one that works with Series 1, Cable or Blue Tooth Thank's |
#23 | |||
5.6L x 2 pilot
Various options here. Cabled versions are a little cheaper. http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40 Stu
#24 | ||
Big Member
Is there a version for E-Series cars?
I missed out on a scanner that was in the for sale section. Lack of $$$ :( Sold on ebay for 65 more than what it was advertised on here for. Double :(
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing Rollin' on genuine ELGT wheels. K&N Filter /////Alpine Sound. EBGT Momo Woodgrain Steering Wheel The Scarlet Fairlane Build Thread Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies PWK Build Thread 1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile. ![]() |
#25 | ||
No there isn't a great deal you can do with the E series as they are OBD1 the AU is a ford version of OBD2 and although most scanners wont work the Forscan software has the ability to work with what's called "standard corporate protocol"
[SIGPIC][/SIGPIC]
#26 | |||
#27 | ||
5.6L x 2 pilot
Gidday Hagar.
Not 100% of Rays sequence for changing BEM etc, but I am sure he orginally had the dummy plug in the passenger air bag and the put the passenger air bag in. Some how he had the air bag light flashing on the dash thereafter. When we cleared the code and resolved the flashing airbag light, Ray plugged the dummy plug back on again, we cleared the DTCs and then re-instated the passenger airbag - no more flashing airbag light! Obviously somehow in the process, a trouble code developed - once cleared, all was good. Cheers Stu
#28 | ||
Nice work guys! watching this thread with interest.
AUII XR6 VCT ute 20 years and still going strong! |
#29 | |||
if I read this correctly I can use ELM327 on my laptop Windows 7 by downloading the correct driver for Win 7 even though the ELM 327 auction listing says no windows 7? I am a windows newbie coming from a Mac household ![]()
#30 | ||
5.6L x 2 pilot
Yes, I am using windows7 Basic on my netbook.
