Old 31-07-2012, 10:18 PM   #31
Pursya
Default Re: Fog lights for WT Fiesta LX
Did you take any pics mate?
Cant get my head around where these clips would be located and how you would force them without damage.
Thanks in advance.
As for the switch you are looking for, have you tried these guys;
******************************.au/
http://www.allford.com.au/
Nothing to lose dropping them an email. There must be some fev zetec's being broken up and the switch would survive most crashes.
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 10:09 AM   #32
Caydus
Caydus's Avatar
Unfortunately, no pics. We were doing the whole thing via torchlight.
I'll take some pics of the final product when i get home today.
The clips are located on the left, right, top and bottom edge of the surround. It is a snap in plastic clip, so to take them off you're going to have to stick a flat head screwdriver in the outside edge of the surround and bend the surround a bit to remove the clip.
Again, if you take the surround off, the front end of your fez is gonna be supremely ugly/ghetto.
You could buy some replacement bulbs and have an auto electrician snap them in for you if you don't feel up to doing it yourself.
Caydus is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2012, 01:20 PM   #33
Caydus
Caydus's Avatar
Gotta love dealer gouging.
Zetec light switch assy is ~$350
One on the LX/CL is ~$90
Old 02-08-2012, 07:48 PM   #34
Pursya
That's a fair point, and not wanting to go in to bat for dealers but...
I contacted an ebay seller of genuine parts, who also turns out to be a SA dealer, about the illuminated gear knob. I can buy the part from the USA for around $160 landed, where the Aussie ebay one was about $260. His reply was that Ford Australia set the prices. He did drop the price to just under $230, but he claimed to be tied to Ford pricing.
I believe him simply because if I were a franchisee and another franchisee undercut me would not be tolerated.
I would be contacting all the ford wreckers in the hope you could salvage the part.
Old 03-08-2012, 08:47 AM   #35
Caydus
Caydus's Avatar
Yea, I checked 4-5 wreckers and no dice. Probably the WT Zetec is still too relatively new/rare to be widely available at wreckers.
I ended up going to a UK based dealer network instead and when we puzzled out which panel would work (they had a huge range of different panels, even for the WS/WT range, auto rain sensing wipers, demisters, etc) it works out to be ~£110 for the switch assembly and £5.75 each side for the surrounds.
We haven't worked out the shipping yet, but I'm expecting around £35 - £40.
Ordering from the US is pretty dangerous though, since their Fez has an entirely re-worked front end and again, left hand drive.
Old 03-08-2012, 09:17 PM   #36
Pursya
The US Fiesta is indeed different inside.
The armrest I am getting for the Fez has to be "Euro Spec" as the American one has different anchor points.
strange but true.
Old 06-08-2012, 12:11 AM   #37
Caydus
Caydus's Avatar
Took a couple of quick snaps today while I was out and there was still sun.
Again, still waiting on the switch and the surrounds, right now the surrounds that are on it are jenky aftermarket ones which are a little too small.
Old 06-08-2012, 10:45 PM   #38
Pursya
Apart from those surrounds being a little small, I reckon the black suits the car.
I note the chrome surrounds on the Zetec blend with the zetecs chrome highlights. With yours the black ones blend well with other black highlights on the vehicle.
Old 10-08-2012, 10:37 AM   #39
Caydus
Caydus's Avatar
Thanks Pursya. I figured a random piece of chrome on the car where there isn't anywhere else wouldn't be too flash hot.
But the package has arrived! Looks like my weekend is sorted.
Old 10-08-2012, 01:11 PM   #40
Caydus
Caydus's Avatar
Now I'm looking at the switch, it looks like the front fog light has an adjustment knob on it as well.
It's a dial you twist that surrounds the button itself. Is that the dimmer?
Old 10-08-2012, 03:37 PM   #41
In Focus
Maybe it's for adjustable headlights. I've got an extra adjuster on my Focus foglight switch (more of a twirly old-radio-style touch, though), but it doesn't do anything because I only have manually adjustable headlights.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
Old 10-08-2012, 04:29 PM   #42
Caydus
Caydus's Avatar
Doing a bit of googling and came across this.
Looks like it's an auto adjustment for the fog lights, specifically pointing it up and down for high/low loads.
Old 10-08-2012, 05:48 PM   #43
Pursya
Yes, adjustable headlights.
The Euro Barina XC had the same thing, though in a different configuration.
Old 11-08-2012, 01:55 PM   #44
Caydus
Caydus's Avatar
So went ahead and installed the new switch and surrounds today.
Started off by taking off the aftermarket surrounds:
The Genuine parts are so much chunkier and fit much better. No rattle and snaps in easily, rock solid.
Genuine:
Aftermarket:
Pulled off the side panel with a flat head screwdriver.
This part really sucked, again, alot of finger hurting twisty action to disengage the upper clip. Lower clip was fairly easy to get to.
Reconnected the wire to the new switch and snapped it back in
The aftermath is some very nice solid surrounds on the lamps and, well, you saw the switch.
Front foggies still dont work
Main High/Dipped beams work, rear fog lights work and the entire switch lights up, the front fog button including the adjustment numbers around it too. Might take it to an auto electrician to figure this one out.
Old 11-08-2012, 08:21 PM   #45
Pursya
Do you need a relay put in to the fuse box to make them work?
Old 12-08-2012, 12:18 AM   #46
Caydus
Caydus's Avatar
Yea, the relay specifically for the front foggies already exists in the fuse box as well as the fuse as well.
But looking at the wires in the loom that plugs into the back of the switch, I'm thinking the wiring may not exist now. There's alot of blanks in the loom. I tried looking up the wiring diagram and tried to find the corresponding wires for all the switches coming off the switch panel and couldn't get all of them to match up (UK book vs AU car?).
Anyway, I think I'll be taking it to a professional shop to have it sorted. If worse comes to worse, we could probably just rig up a separate relay and plug it into the blanks in the loom.
Old 12-08-2012, 01:34 AM   #47
Caydus
Caydus's Avatar
Been pouring over a few wiring diagrams in this thread and I can confirm there's a wire in the slot for the front fog lights that corresponds to the colour combo listed in the wiring diagram.
Oh man, i really hope it's not the switch
Old 12-08-2012, 10:54 AM   #48
Pursya
As you have discovered, the wiring would exist.
Economies of scale means there is no alternative wiring looms made these days.
Old 12-08-2012, 11:53 AM   #49
trumpy73
wouldn't be easy to test whether it's the switch or not by manually shorting the actual wires? or is that too risky?
trumpy73 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2012, 04:31 PM   #50
Moorie
No need to short anything, just put a voltmeter (or one of those circuit testers that have a small globe in the handle) across the two points and see if a circuit is created when you switch the lights on. If yes, you have an issue with the cabling from the switch to the lights.
Moorie is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2012, 03:52 PM   #51
Caydus
Caydus's Avatar
Done some work on the multimeter and was able to check everything seems to be fine and matches up 1:1 with the wiring diagram i have from my Haynes workshop manual, so I took it into a auto electrician.
They told me that again, nothing's wrong with the wiring and there's no conceivable reason why it's not working. The one most probable reason they came up with was that since it runs through the fusebox, the ECU most likely has some measure of control over the systems.
Just called a Ford dealer's service dept and they say there's a Central Control System on these new cars and most likely that's got something to do with it. Waiting for him to get back to me with an answer from the ford dealer technical hotline now.
Old 30-08-2012, 10:33 PM   #52
Caydus
Caydus's Avatar
Success!!!
Entirely factory setup, even dash light turns on when the foggies are on.
Old 30-08-2012, 10:55 PM   #53
Pursya
So what was the problem?
Look great btw.
Old 30-08-2012, 11:00 PM   #54
Caydus
Caydus's Avatar
Cheers mate,
Electrically, there was no problem with the install. It was the central electronics management system that didn't recognize this model as having Fog lights.
Took it to Thompson Ford over at Parramatta and they hooked it up to their computer and enabled the option for me.
Worked pretty much right after the switch was flicked. It's got the same on parameters as the rear fogs though.
Would only work if you have the low beams on and has to be turned on every time you start the car
Old 31-08-2012, 11:13 PM   #55
vhcbm
having Fiesta withdrawals
vhcbm's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Ford couldn't fix my BlueTooth issue. This member posted a download link, with instruction, on how to do it myself. One week on, the unit hasn't played up once. Three different dealers told me to virtually 'Live with it.
Looks great! Certainly something different. Well done on persevering with it.
New: Ford Focus RS in Ultimate Green number 82/315
Past: 2009 Ford Fiesta LX in Vision Blue - Sold
vhcbm is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2013, 12:53 PM   #56
a pirate
a pirate's Avatar
digging up an old thread ta for doing the leg work i can also confirm loom, relay and fuses are there just missing the switch in the switch box on the dash.
Priced around from the wreckers zetec light switch is $110. on the shopping list now.
also now i know what the box looks like and how its clipped in, it is easier to remove the little pocket below and reach up and unclip the light switch box....that way you do not need to unscrew or pull any parts off the car.
Currently have;
2010 Subaru Forester XT Lux with 210awkw
2011 Ford Fiesta WT LX hatch (diesel)
Use to have;
2005 Mazda 3 SP23 highly modified with 130fwkw
2000 Nissan Pulsar LX
1988 Toyota Celica GT coupe
a pirate is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 05:05 PM   #57
ebv8
ebv8's Avatar
did ford charge you to hook it up to the computer to activate the fog's
i'm trying to get my cruise working as all wiiring is there and all the switches but the local ford dealer says there is a day in it and leave it with them and they will add all the parts they need to finish it, they were not interested in hooking it up and activating the cruise control just to see if it works
when i get my fogs in i might call a few dealers to see who wants to do it
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2013, 06:32 PM   #58
Caydus
Caydus's Avatar
Yea, they charged me for it. Thompson Ford in Parramatta did it for $100. At that point, I was just sick and tired and just paid for it, but in hindsight, could have probably gotten them to do it for less or maybe even free if the car was in there already for something else.
The switch and fog surrounds were around $110 from Hendy Group in the UK too, brand new.
Old 16-11-2013, 09:29 PM   #59
a pirate
a pirate's Avatar
Ive bought, installed, wired, tinkered and now just waiting for my next service to actvate the ecu to recognise foggies are installed.
Currently have;
Use to have;
