CNC fixer guy
Hi guys,
Considering the minority of au's with irs and the lack of knowledge or even it's existence, would it be a good idea to have a thread or sticky just for this case entailing info, problems and solutions for au irs? What do you think? |
CNC fixer guy
Ok so i take it its not a good idea then.
The other issue i have is the rear end skipping sideways a little over small bumps or joins in the road etc. |
Lacking Imagination
I have the same,
My Steering joint told me to check my swaybar links as they looked worn!
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
When in doubt, GAS IT!!
Check your upper control arm outer spherical joints, that's what was cactus on mine when it did that.
CNC fixer guy
Hi basher. All my outer sphericals are new and the inners seem to pass the crow bar test.
Will get a 4 wheel alignment soon and see if it helps could also be rear struts a tad worn. Upper strut mounts have been modified to fix the usual problem there. Cheers. |
