Old 09-10-2013, 02:46 PM   #1
james22
With da Warlords
james22's Avatar
Default Wiring Harness Open Circuit???
Hi all.
Just hooked my xr up too an elm327 scantool using forscan.
It popped up with one DTC.
RCM - B1877
Code; B1877 - Safetybelt Driver Retractor Circuit Failure
Module; Restraint Control Module
Details; Wiring Harness Open Circuit.
So my question is, what does this mean? And how do I fix it?
Also noticed my IAT is reading -15C, think its buggered too lol
Cheers,
James
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2013, 05:13 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Wiring Harness Open Circuit???
it's a seatbelt pre tensioner fault. I had the same but it was just the plug on mine
[SIGPIC][/SIGPIC]
Rides:
Old 10-10-2013, 08:50 AM   #3
james22
With da Warlords
james22's Avatar
So If i pull the bottom half of the pillar where the seltbelt goes, I should find the tensioner down there somewhere
Windsor Warlords
AU III XR-8220
Old 10-10-2013, 09:02 AM   #4
FGII-XR6
FGII-XR6's Avatar
no, the pretensioner is in the part attached to the seat it is part od the buckle . the connection is under the seat
[SIGPIC][/SIGPIC]
Rides:
Old 10-10-2013, 09:57 AM   #5
james22
With da Warlords
james22's Avatar
Ahhh, cheers for that. Definitely plugged in, so I'll have to check it out
Windsor Warlords
AU III XR-8220
Old 10-10-2013, 11:03 AM   #6
FGII-XR6
FGII-XR6's Avatar
one might be faulty, if you can get hold of a spare set for testing try swapping them over
[SIGPIC][/SIGPIC]
Rides:
