15-08-2013, 08:55 PM | #1 | ||
Hi All, My AU series 2 Auto Ghia sedan is making a whinning noise which seems to be coming from under (or just behind) the centre console. Cant hear anything until 40KPH and them the noise starts and increases as speed increases. Auto issue perhaps? Ant ideas? Anyone had this sound in there AU. THX.
18-08-2013, 09:33 AM | #2 | ||
Hmmm, looks like no one has had this issue. Off to the mechanic then.
18-08-2013, 02:36 PM | #3 | ||
Noises are a tuff call over the internet old mate, and can be deceptive at the best of times, good luck , let us know what you find.
18-08-2013, 03:13 PM | #4 | ||
Could be a whining diff.
My Ride... 2005 BA2 XR6 Magnet Ute. |
18-08-2013, 04:10 PM | #5 | ||
My blue au had that whine it was a ****** trans
18-08-2013, 06:43 PM | #6 | ||
Next upgraded Mk1 Leopard
I'm so glad no one posted get your partner to move to the back seat and see if it helps...oh no I just did.. bugger
UK
18-08-2013, 06:50 PM | #7 | ||
I ♥ EDM
Id say one of 2 things; the diff or a wheel bearing.
Wheel bearing whine is very distinct, sounding like an old prop driven aircraft. And its loud as hell at highway speeds. |
18-08-2013, 07:26 PM | #8 | ||
Too many Fords........ :)
Was the missus in the passenger seat?
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it |
19-08-2013, 12:07 AM | #9 | ||
19-08-2013, 12:41 AM | #10 | |||
Been there and done that. In my case, a trans service and flush, solved the problem. (clearly hadn't been serviced in a very long time!)
22-08-2013, 06:52 PM | #11 | ||
Turns out its the diff. Needs to be a reconditioned. Ouch lots of $'s
22-08-2013, 08:52 PM | #12 | ||
Recommend Agmech in Boronia for diff rebuilds.
They just did my old mans VS commodore ute diff. Cost $700.00
22-08-2013, 09:05 PM | #13 | ||
Thx, SPArKy Dave, I was quoted $1800+, due to the type of diff in the AU. Would this be right? Will ring Agmech tommorow.
22-08-2013, 09:25 PM | #14 | ||
Depends...... maybe you have an IRS rear end?
Keep us posted!
22-08-2013, 11:22 PM | #15 | ||
Yes, its has an IRS rear end.
22-08-2013, 11:30 PM | #16 | ||
meh.
Still, being an IRS rear end it isn't that hard to drop the center, once the axles, 4 or 5 bolts, and driveshaft is all out/disconnected, it should drop straight down.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
23-08-2013, 08:09 AM | #17 | ||
My mechanic told me it takes 5 hours to get the diff out?
23-08-2013, 02:09 PM | #18 | ||
meh.
I doubt it, even with removing the entire cradle, removal shouldn't take more then an hour, unless your mechanic doesn't know what he's doing.
23-08-2013, 09:32 PM | #19 | ||
5 hours to get it out ??? Wow , maybe 1.5 tops . It's a simple IRS rear end .
I would get a 2nd opinion mate .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
23-08-2013, 10:07 PM | #20 | ||
Iam getting a second opinion, taking the car to Agmech in Boronia on Monday for them to test drive.
26-08-2013, 07:18 PM | #21 | ||
Took the car to Agmech in Boronia today, the guy test drove the car and tells me its the left front wheel bearing! Who to believe?
26-08-2013, 07:32 PM | #22 | ||
Critical Thinker
Go with the cheapest option first.
In saying that, the AU wheels bearings are a sealed, all in one unit. Fairly rare to see them pack up, but if it is a bearing, it is and will be a complete bearing assembly. Not cheap, but still cheaper than the option of the diff. That time frame is stupid. Its clear the guy has no idea. If it were me, I'd get the trans serviced first. Full flush and service. If it turns out not to be that, so be it, its cost you what? $120? and you know the trans is serviced for another 20,000km. Then move onto the wheel bearing suggestion, and so on. Like others have said, too hard to know over the net, and it's basically speculating.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
27-08-2013, 08:22 AM | #23 | ||
Thx Blueoval, I have had the same idea, have had the transmission done full flush and service, all ok, tommorow will get the bearing done.
When I swerve hard to the left the noise momentarily stops, when I swerve to the right the noise is constant. Think it is a bearing...I hope lol. |
27-08-2013, 11:15 AM | #24 | ||
Critical Thinker
Sounds plausible that its a wheel bearing then mate. Let us know the outcome.
27-08-2013, 11:33 AM | #25 | ||
Resident AFF detailer
Yep sounds like a bearing. Have had both ones at the front replaced in the last few years, sounded exactly as you've described.
28-08-2013, 06:52 PM | #26 | ||
Update, its was the front left wheel bearing. All is now nice and quite. I hope this thread helps others who start to hear this difficult to identify noise/issue. The whining noise actually sounded as if it was beneath the centre consol and sounded (as someone earlier stated) like a droning propeller.The noise obviously travelled through the chassis. Hopefully this will help others who (as I did) do a search for "whining noise AU".
28-08-2013, 11:08 PM | #27 | ||
All Bran = Regular Member
30-09-2013, 09:58 AM | #28 | ||
GIVIT Rally 84 BARRA XE
Can confirm this same issue, sounds like a diff is gone, but I consider my AU3 ghia at only 140000 genuine kms it hasn't done enough to be diff yet. I thought something wasn't right when the other night I rode in the passenger seat, and just sitting on the other side of the car the noise sounded to be coming from a different place in the car. Left front was the issue.
Thanks ron, your pictures and story make it look easy.
XT BF2 SZ BA XG E Outback Ute XE BARRA - http://www.fordforums.com.au/showthread.php?t=11382891 - 2007 GER Via Birdsville, 2008 via Broken Hill, 2009 via Cape York, 2012 via Karumba, 2014 via Innamincka, 2016 GIVIT RBR, 2017 via Boulia, 2018 Via Mighty Murray, 2019 Via Dig Tree, 2020 Via Thargomindah, 2021 Via Lawn Hill Gorge, 2023 Westmar - Gunnedah Sponsors, London Fire & Safe www.fireextinguisher-and-safes.com, G&D exhausts and suspension Beenleigh , Beenleigh Bob Jane |
