Old 04-09-2013, 06:57 PM   #1
madeinasia
Default AU Coolant Fans
Hi
I have an AU 6 cylinder Auto ute.
The Coolant Fans are not coming even when the engine is hotter than normal or when the AC is on.
I have disconnected the wire from the Temperature Sender unit and both fans start working ok.
Is it simply a matter of changing the Sender unit of could it be something more.
If it is the Sender Unit can someone tell me how do I get it out, or even what size spanner is needed
Hope someone can help me
madeinasia is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 07:04 PM   #2
SirHenry
Falcon Unbelievable!
Default Re: AU Coolant Fans
Have you checked the fans themselves? Could be a dust build up inside I had that about a year or 2 ago. The dust built up that heavily it clogged the fan motor.
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 07:11 PM   #3
madeinasia
Thanks for your quick reply Sir Henry.
Once I take the Temperature Sender wire off the fans spin fine. I just want to find out if it is the sender before I take it off as it is a difficult job to remove
Old 04-09-2013, 07:32 PM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Is your temp gauge working ok? At running temperature the needle should be sitting between the N and the O on the gauge where it says NORMAL.
MINE- AUII Forte
Old 04-09-2013, 07:38 PM   #5
madeinasia
When the temp sender is connected the gauge is just below normal most of the time however as the fans are not working it will heat up in the city traffic or on hot days. I just want to confirm from somebody here that it is the Temp Sender before proceeding futher
Old 04-09-2013, 09:48 PM   #6
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hi madeinasia welcome to AFF, I would look at your fan relays too in the fusebox under the bonnet before changing the temp sensor.
cheers, Maka
Old 18-09-2013, 12:06 AM   #7
madeinasia
Hi Maka, you are a star. I swapped out all three relays and bot fans now work as they should. Dont know how I would have got that Temp Sender out. Noel
Old 18-09-2013, 07:55 AM   #8
Maka
Maka's Avatar
Well done on finding the issue with your fans, hopefully all good now
cheers, Maka
Old 18-09-2013, 01:43 PM   #9
Bushbasher
Bushbasher's Avatar
Sorry, I haven't got back to this thread for a while, and I'm glad you got your fans working, but if your temp gauge is sitting below the "N" most of the time then I'd suggest you check your thermostat as it sounds like it's stuck open. This will cause the engine to run cold and the ECU to run in open loop. Basically, it's like running with the choke on all the time so your economy won't be particularly flash if this is the case.
Bushbasher
MINE- AUII Forte
Old 19-09-2013, 01:54 AM   #10
madeinasia
Thanks Bush. Normally the Temp Gauge is at 10 o'clock. The thermostat was changed 12 months ago and the system was flushed. If you think that this is too cool I might look at getting another thermostat as I am planning to fit a new heater tap and the heater hoses underneath as there is a slight leak around that area.
Old 19-09-2013, 10:09 PM   #11
Bushbasher
Bushbasher's Avatar
The temp gauge needle should be sitting between the N and the O on the gauge where it says NORMAL if the thermostat is the correct one and is working correctly.
Bushbasher
MINE- AUII Forte
