Old 16-09-2007, 08:52 PM   #1
TomXY
XY
TomXY's Avatar
Default 250 and T5 into 4 cylinder TE body
hey,
can anybody tell me how hard it is to fit a 250 crossflow and T5 gearbox into a TE cortina? Do you need to modify the firewall or anything? originally the car was a 4 cylinder, 5 speed manual... Just wondering what parts ill need?
im assuming its legal to do, and you dont need an engineers certificate?
thanks
tom
IGOTTABIGBLACKSHINEYCAR
TomXY is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 11:34 PM   #2
P100 Ute
P100 Ute's Avatar
no firewall mods..
u just need to cut a new shifter hole which sits roughly 100mm further back.
as for legalities i dunno.. i never got pulled over and checked.
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 07:34 AM   #3
TomXY
XY
TomXY's Avatar
thanks P100, will the normal crossflow mounts for a falcon fit a cortina?
Old 17-09-2007, 10:34 AM   #4
P100 Ute
P100 Ute's Avatar
you'll need a set of 6cyl cortina mounts.. both the engine mounts and the mounts that mount to the chassis.
Old 17-09-2007, 06:20 PM   #5
TEaaron
TEaaron's Avatar
Don't forget the sump.
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2007, 09:20 PM   #6
TomXY
XY
TomXY's Avatar
what about the tail shaft?
Old 18-09-2007, 02:42 AM   #7
P100 Ute
P100 Ute's Avatar
auto tailshaft will fit with no drama's.
if your putting a XF Falcon 250Xflow in ... you'll need a Cortina Pickup/Sump and the 2 Main Bolts the Pickup bolts to..
but if its a Cortina 250Xflow motor.. the sump will be correct.
due to the Bowl been @ front on Falcon.. and Rear on Cortina
Old 18-09-2007, 10:13 AM   #8
braddyxe51
cortyboy
braddyxe51's Avatar
Should be legal with out cert, cos cortys came with 6s
braddyxe51 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2007, 02:39 PM   #9
P100 Ute
P100 Ute's Avatar
he's prob talking about cutting out the hole for the gearbox....
braddy.. did u get the photos i sent u of the extractors ?
Tim.
Old 18-09-2007, 03:25 PM   #10
TEaaron
TEaaron's Avatar
I sealed the hole I cut for my t5 with 4mm plate works good.
Old 18-09-2007, 05:36 PM   #11
TomXY
XY
TomXY's Avatar
cool, what about crossmember?
Old 18-09-2007, 07:49 PM   #12
TaraHymen
TaraHymen's Avatar
u can use the original crossmember and redrill it to suit the t5 rear mount. u'll need to unstitch the crossmember mounts from the floorpan, bolt everything up and reweld them. cortina tailshaft and speedo cable will plug into the back end of a t5.
TaraHymen is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 08:55 PM   #13
tecortina
Default Re: 250 and T5 into 4 cylinder TE body
can anyone help me get 6cyl body mounts? im coverting my 4 cyl to six
tecortina is offline   Reply With Quote Multi-Quote with this Post
